A2251 No power/ Stuck in DFU
  • tommy97
    • Mar 2023
    • 159
    • United Kingdom
    i'm having a problem with A2251 after the liquid damage, before it got to us, customer went to other repair store, and we don't know what was done. Laptop stucked on 20V 0amp, i tried to revive bridgeOS no luck, error -1.
    PP3v3_S5 - Normal
    PPBus - Normal for DFU
    PP2v5_NAND_SSD_0 - normal (and resistance about 45Ohm)
    Liquid damage was mainly next to ISL from that what i've noticed.
  • mon2
    • Dec 2019
    • 14316
    What is the exact voltage to ground of PPBUS_G3H​? PP2v5_NAND_SSD_0 ?
    • mon2
      • Dec 2019
      • 14316
      The error code -1 indicates that the device is unable to communicate with the Apple server.
      Check your internet connection - use a reliable USB to Ethernet port adapter (with Asix controller is recommended).
      • tommy97
        • Mar 2023
        • 159
        • United Kingdom
        PP2v5_NAND_SSD_0 2.5V
        PPBUS_G3H 12.59V
        "The error code -1 indicates that the device is unable to communicate with the Apple server." - got an Ethernet adapter, DFU seems to go through, now it shows me that screen, no changes, tried update through DFU and it says that action cannot be done.
        • tommy97
          • Mar 2023
          • 159
          • United Kingdom
          Any idea what to check further? mon2
          • mon2
            • Dec 2019
            • 14316
            Review the last 2 posts here and keep updating this thread:
            https://forums.macrumors.com/threads...dlock.2293187/
            • BMCappelletti
              Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
              by BMCappelletti
              Hi everyone.
              Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
              Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
              Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
              02-18-2025, 12:22 PM
            • Arshad alam4659
              a2251 5v stuck 270ma
              by Arshad alam4659
              macbook pro a2251 820-01949-a 5v stuck i checked all ldo ok ppbus_g3h is 12v pp3v3_g3h 3.3v all SLPS2R volt ok i try in dfu but gave me this error 4042...
              10-27-2024, 01:21 AM
            • Instafixx
              Macbook A2179 820-01958
              by Instafixx
              Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
              The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
              I checked the Power Sequences below and found this -
              Once a valid external power source (Charger or battery) is connected, the following rails will come online.
              PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
              PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
              05-20-2023, 05:19 AM
            • tommy97
              A2251 No power liquid damage - DFU
              by tommy97
              i'm having problem with A2251 Board after liquid damage was mainly next to CD3217 LEFT side & U9000, 3.3v, 1.5v, LDO's all on with correct measurements. Device cycling in between 0.10-0.20amp 20v, while battery connected goes to up to 2amps.
              While trying to revive device, show error 4010 and then go to recovery instead of DFU, checked nand resistance no short, Ohm within the range.
              02-10-2024, 06:41 AM
            • ronelex
              Macbook Pro A2251 Stuck on 5v
              by ronelex
              Hi everyone, I have this unit A2251 820-01949.
              I receive this unit with a shorted PP3V3_G3H and found the culprit C8161 shorted and I remove it but the unit still stuck at 5v 0.04A
              This are the readings I got on the unit
              PPBUS_G3H -12.33v
              PP1V8_SLPS2R -0v
              PP3V3_G3H_PMU_VDDMAIN/PP3V3_G3H - 0v
              P1V8G3S_EN from u7800 - 0v
              U3100_W
              PPHV_INT_G3H_W - 5v
              PP1.5_UPC_LDO_CORE_W - 1.5
              PP3V3_UPC_W_LDO - 3.3V
              PP3V3_G3H_RTC - 3.3V
              U3100_R
              PP1.5_UPC_LDO_CORE_R - 1.5
              PP3V3_UPC_R_LDO - 3.3
              PP3V3_G3H_RTC...
              12-17-2023, 10:28 AM
