Macbook Pro A2251 Stuck on 5v
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Hi everyone, I have this unit A2251 820-01949.
    I receive this unit with a shorted PP3V3_G3H and found the culprit C8161 shorted and I remove it but the unit still stuck at 5v 0.04A
    This are the readings I got on the unit
    PPBUS_G3H -12.33v
    PP1V8_SLPS2R -0v
    PP3V3_G3H_PMU_VDDMAIN/PP3V3_G3H - 0v
    P1V8G3S_EN from u7800 - 0v
    U3100_W
    PPHV_INT_G3H_W - 5v
    PP1.5_UPC_LDO_CORE_W - 1.5
    PP3V3_UPC_W_LDO - 3.3V
    PP3V3_G3H_RTC - 3.3V
    U3100_R
    PP1.5_UPC_LDO_CORE_R - 1.5
    PP3V3_UPC_R_LDO - 3.3
    PP3V3_G3H_RTC - 3.3
    U3100_X
    PP1.5_UPC_LDO_CORE_X - 1.5
    PP3V3_UPC_X_LDO - 3.3
    PP3V3_G3H_RTC - 3.3
    U3100_T
    PP1.5_UPC_LDO_CORE_T - 1.5
    PP3V3_UPC_T_LDO - 3.3
    PP3V3_G3H_RTC - 3.3​
  • mon2
    • 14713
    Remove all power. Measure the resistance to ground on the power rail that is at 0 volts. Repeat for the enable line for that rail that is also at 0 volts.
    • ronelex
      • Oct 2016
      • 195
      • Philippines
      PP1V8_SLPS2R -3.7k ohms
      PP3V3_G3H_PMU_VDDMAIN/PP3V3_G3H - 2.4 mega ohms
      P1V8G3S_EN from u7800 - 40k ohms
      I got this low ohms reading on
      L8100 /PP1V1_S3_REG_R - 2.5ohms
      I dont know if this is normal because I dont have any identical board onhand
      • mon2
        • 14713
        Post the diode mode readings of L8100. Remove all power. Meter in diode mode.
        red meter probe, yes red to ground.
        black meter probe to L8100.
        follow this thread - may be the same fault:
        https://boards.rossmanngroup.com/thr...6-0-35a.62664/
        post your updates.
        • ronelex
          • Oct 2016
          • 195
          • Philippines
          ok thanks for the guide sir, I will update after I check it again
          • mferna14
            MacBook Pro A2251 820-01949-A stuck on 5V
            by mferna14
            Hi Dear friend., I am working MacBook Pro A2251 Logic board 820-01949-A. The history was that there was slight liquid on the LHS CD3217 & was not powering on at all. No 20v or any amps. I replaced with known good CD3217s & then got the power but its stuck on 5V .18amp. I did power measurements which are below:
            PPBUS_G3H=12v
            PP3V3_G3H=3.3v
            PP3V3_UPC_X_LDO=3.3v
            PPDCIN_G3H=5v ????
            PP1V8_SLPS2R=1.8v
            Do you think the other RHS CD3217 have to be replaced to as they might have gone defective????​
            11-08-2024, 05:35 PM
          • Runnerboys
            Macbook a2251 Water damage- stuck on Logo
            by Runnerboys
            Would appreciate your input, we have fixed a water damage motherboard for the a2251, there was mainly corrosion next to the 2 locations, but were able to clean it all
            First few times- the Macbook would boot and got to login screen (didn't try to login), day after, when we tested it - it would get stuck on the logo and won't show welcome screen
            What would be the best step to take from here to test? should I test Mobo components/ chip / storage? and if so- where do I start?
            OR should I try to use the Apple Configurator and connect...
            05-17-2023, 11:40 PM
          • Bmet
            MacBook Pro 13 inch A2238 M2 stuck on 5V
            by Bmet
            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
            04-02-2025, 05:02 PM
          • conghuyms
            MacBook Air A2179 stuck logo , pls help me !
            by conghuyms
            Hey everyone,
            I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
            When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
            I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
            11-05-2025, 08:30 AM
          • modtool
            Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
            by modtool
            Dear friends,
            a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
            I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
            I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
            Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
            10-25-2025, 05:09 AM
