A2251 No power liquid damage - DFU
  • tommy97
    • Mar 2023
    • 159
    i'm having problem with A2251 Board after liquid damage was mainly next to CD3217 LEFT side & U9000, 3.3v, 1.5v, LDO's all on with correct measurements. Device cycling in between 0.10-0.20amp 20v, while battery connected goes to up to 2amps.
    While trying to revive device, show error 4010 and then go to recovery instead of DFU, checked nand resistance no short, Ohm within the range.
  • mon2
    • 14334
    Error 4010 is often related to network issues with the DFU tool in attempts to reach the Apple server.
    What is the voltage to ground of PPBUS_G3H @ fuse F7000? Check both sides. If the voltage is not normal, flux and remove this fuse. Then meter in resistance mode, measure the resistance to ground on each side of this removed F7000 fuse using the PCB pads.
    Post all measurements.
    • tommy97
      • Mar 2023
      • 159
      While battery is disconnected it does show 12.60V, when connected it goes from 11.3v to 12.1v
      • mon2
        • 14334
        12v6 means that the ISL9240 buck / boost regulator has been boosted to the correct value. When the battery is connected, it does not get boosted to the proper value. The SMBUS lines which are shared with the battery pack are used for this voltage shift.
        Carefully measure the voltage to ground on the battery connector. Specifically interested in the SMBUS SCL and SDA measurements to ground when the battery is connected. This may mean that your BMS (battery management system) board on the battery pack is defective. Not 100% sure but Tim @ TCRS does chat in his videos about certain macbooks that require for a known good battery to be present in order to boot properly. This may be one of those models.
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • Jenzo
          MacBook A1989 overheating after liquid damage
          by Jenzo
          Hey everyone,
          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
          I can't figure out how...
          05-13-2023, 07:58 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
        • larrysito111
          dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
          by larrysito111
          got here a liquid damaged alienware
          the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
          so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
          so with the usb-c external monitor is getting to bios and OS
          otherwise not
          so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
          but still not the internal monitor
          (tested 3V and 5V going to the...
          06-12-2025, 04:16 PM
