Gateway NV78 power LED comes on, fan spins, unresponsive after a few seconds
  • withalligators
    • Jun 2013
    • 267
    Hey gurus,
    I have a gateway NV78 with a problem. It can charge a battery. The LED indicator light turns on when you press the power button, the CPU fan will kick on, and that's it. A few seconds later, it goes unresponsive and the fan shuts off, but the LED light will stay blue. If you hold the button down for a few seconds, the light will turn off. No response from screen or any key inputs. If I take the heatsink off, the CPU fan will turn on and stay running, so the heat sensor works.
    I've tried starting it without ram, without a DVD drive, without an HD, a different CPU, and without the battery, no change, no BIOS post beeps, nothing.
    I've read in a few places about this problem, and seen a few solutions, none of which work for me. I've tried the 30 second power reset by holding the button, taking apart the power switch, and starting it upside down.
    The last thing I can think of is replacing the CMOS, but I can't ID it. Will post pics shortly, but does anyone have any experience with this or the NV52?
    Thanks,
    Alex
  • dj_ricoh
    • 2073
    • uk
    Re: Gateway NV78 power LED comes on, fan spins, unresponsive after a few seconds
    this gateway its 1 on 1 with packard bell.
    does it have dedicated video card?
    • withalligators
      • Jun 2013
      • 267
      This one unfortunately does not have either of the nvidia or ati options, but the intel GM45 chipset. But it isn't integrated on the CPU, it is soldered onto the MB under the same heat sink as the CPU.
      • dj_ricoh
        • 2073
        • uk
        unplug lcd test with external.
        other cpu,ram.
        find a schematic for the mobo so we all can talk
        • withalligators
          • Jun 2013
          • 267
          Hi, tried all three, can't find a schematic. I googled it, and looked on elecktrotanya. Where else should I be looking? I've never needed one to repair a lappy before, so it's kind of new to me. MB is Kayfo LA-5021p.
          • withalligators
            • Jun 2013
            • 267
            Gave up and bought a MB off ebay for 50 bucks. Up and running now.
            • twonk9098
              Lenovo Legion 5 high fan spin turns off after 34 seconds
              by twonk9098
              I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
              I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
              I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
              I have tried a few new bios but exactly...
              07-14-2024, 11:19 AM
            • pronester
              Cooler Master 550 watt - fan spins few seconds and then stop
              by pronester
              Hi guys,
              i got this broken computer PSU with model number MPX5501AMAAB.
              i detected that 1 of the diode (model number: SB2100) was broken and replaced with a new one. but that not solved the issue as the problem is still persists which indicates that other components are also shorted. maybe someone can advice on what to do next?
              I attached some pictures for reference.
              on the other hand, i encountered quite a few PSUs with the same problem..i.e the diode is shorted/opened but replacing it not solving the issue..may this be a good indicator...
              11-07-2022, 03:56 AM
            • liquidzorch
              Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
              by liquidzorch
              Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
              10-18-2024, 05:19 PM
            • Rick_1234
              by Rick_1234
              Good evening, gentlemen.
              Things I tried
              06-22-2024, 04:44 PM
            • PowellSkier
              Harman/Kardon AVR 645 returning to stand-by after a few seconds.
              by PowellSkier
              A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
              06-17-2024, 11:43 AM
