Laptop Asus Strix G15 power up, but always black screen
  • Themonster
    • Feb 2023
    • 13
    • Spain
    Hi im Monster ("nickname"), i will explain what happens with this laptop pc:
    Asus Rog Strix G15 : model = G512LW
    The screen is not broken, almost not physically.
    When i power up the computer this run perfect but nothing show in screen, also in HDMI port.
    More or less 10 sec later, when win 11 is loaded , HDMI show things i mean user login in win 11.
    Original or main screen doesn't works, anytime, but HDMI works fine when win11 load nicely.
    When win11 is loaded , i check device administrator, and i found a system firmware error, so what i need to do to fix that, i need flash bios? what means system firmware marked as error, .
    Is that the problem.
    I cant go to bios menu , its like no exist bios, because f10 and enter will shutdown if u are inside bios menu, but never shut down.
    The problem that,and what i need to solve is:
    What i need to do for solve firmware problem.​
    If the probles is the bios i need a version for ch341 because oficial bios doesnt work with ch341, almost i know.ç
    If some one have similar problem or have bios i will very ty for you help .
  • Themonster
    • Feb 2023
    • 13
    • Spain
    I alreay tryied to installing with myasus, but im sure that will no work.
    • mon2
      • Dec 2019
      • 14634
      Try the EZ update tool:
      https://www.asus.com/support/FAQ/1012152/
      • Themonster
        • Feb 2023
        • 13
        • Spain
        I cant go inside Bios , black screen i can not see anything, the pc doenst go inside bios menu if i press f2
        Let me explain when i pres f2 win11 doesnt wake up, so i use f10 to save and exit to load again win 11, but f10 and enter, doesn't work.
        So win11 don't turn on again until y restat manually, presing power button 1 time to shutdown and again to start up.
        • Themonster
          • Feb 2023
          • 13
          • Spain
          Im trying to do the modify bios from Ez utillity tool, but im stuck at the chose CSME version
          • Themonster
            • Feb 2023
            • 13
            • Spain
            Laptop asus strig g15
            Model: g512lw
            S/N: L5NRKD002295208
            Y posted my bios, i tryid to do it my self but i cnat do it, i dont have any programs for make a new bios using my old bios. Also i dont know check a bios file and if this is correct.
          • mon2
            • Dec 2019
            • 14634
            Hi. Please post this request in the dedicated bios forum.
            • Technodoc
              ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
              by Technodoc
              Asus laptop G614JZ-N3012W Rog Strix with i7
              Mainboard G634J-PMV-VGT
              6050A3441302-MB-A01
              2023-02-10
              Power button works okay....power light goes on
              Red "bottom" leds go on
              Charging led works
              Fans do not spin, capslock key does nothing, screen stays black
              I would like to program the bios again, to rule out a corrupted bios.
              However I run into a size error
              The bios chip is a Winbond 25R256JVEN
              Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
              02-24-2025, 04:46 AM
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • LtCdrData
              ASUS Rog Strix 6050A3441302-MB-A01 BIOS
              by LtCdrData
              I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
              ASUS Rog Strix Scar G18 G834JY-XS97
              latest version 331 or oldest 317 would be great. thanks!
              https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
              09-16-2025, 06:13 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
