Surface Pro 7 1866 No Power
  • Powerup
    • May 2017
    • 16
    Hey guys,
    I go a surface pro 7 in at the shop with a broken screen but reception did not test it and its totally dead. usb c Charger negotiates 20v and about 500ma which spikes to 1.8a on power button press and then back down to about 800ma. I have board view and schematic but I am kind of spinning my wheels here and am hoping someone can give me some info to help me understand what I am looking for a little better.
    update: Following the power sequence up to the LPC, 1p8v_sam is present as well as pwrbtn#_1v8, No vsus_on tho. Is LPC what I should be looking at?
  • Powerup
    • May 2017
    • 16
    also hoping I didnt possibly trip thermal protection at u5801 but I am unsure how to determine that. I do not own an oscilloscope. Ive attached the BV and schematic for anyone who wants to have a look
    [MOD EDIT] Link to Schematic & Boardview -> https://www.badcaps.net/forum/troubl...-and-schematic
    Reminder: rules and organization of this section -> https://www.badcaps.net/forum/troubl...f-this-section
    • Powerup
      • May 2017
      • 16
      as an update, schematic calls for nominal vsys voltage of 8.6v But I am only getting 6v. other voltages seem a little low as well like 1v7 on 1v8 lines ect. hoping someone can offer some advice here
      • Powerup
        • May 2017
        • 16
        viewing under thermal, U6204 gets hot and the 1p8vsb_vcc on pin 8 is actually 3.3v. hoping anyone can help me make sense of what I am seeing here
        Click image for larger versionName:	hot.pngViews:	0Size:	860.3 KBID:	3182648
        • mon2
          • Dec 2019
          • 14213
          Remove all power. Meter in resistance mode. Measure the resistance to ground of this lower voltage rail. Checking for a low resistance which may mean you have a shorted component on this power rail. Often a shorted or leaky capacitor.
          • Powerup
            • May 2017
            • 16
            is it safe to assume then that seeing 3v3 on pin 8 which is labeled as 1p8vsb_vcc should be 1v8? Because the buck u6204 heats up and I am not 100% on what the function of this component is.
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • Danny Butler
              Surface Pro 7 wont power on (1866(
              by Danny Butler
              Quick Backstory, the Surface Pro was in the back of my car, and got some liquid inside it (didnt know at the time and charged it, and tried to power it on)
              The area it affected was the botttom side of the board near and including the usb ports...see photo)
              it was only damp in that area for around 3/4 days, i cleaned the area with isopropyl alcohol and a gentle brushing.
              obviously it didn't boot up (as I'm here) i've downloaded the board diagrams, (and used referenced from another post, Surface Pro 7 1866 won't turn on... - Badcaps​)
              when pressing the power button...
              04-26-2025, 04:34 AM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
