MacBook A1989. Stuck in DFU and won't turn on!
  • bilel
    • Mar 2019
    • 31
    To Update need to connect to recovery mode and install os online by wifi .T2 chip not accept restore by apple configurator only serie M1 and M2
    • PITERPENY
      • Jul 2023
      • 463
      • Ukraine
      this is understandable! just explain how to get out of the dfu if it’s stuck in it? To start Internet recovery you need to correctly complete the DFU mode!
      • mon2
        • Dec 2019
        • 14726
        MacBook Pro A2141 stuck in DFU mode | Rossmanngroup Forums
        • PITERPENY
          • Jul 2023
          • 463
          • Ukraine
          I haven’t reached the activation window yet, it doesn’t work with the DFU!
          • mon2
            • Dec 2019
            • 14726
            From post # 4, we know that PPBUS_G3H created by U7000 is not yet boosted to the ~13 volts by the SMC.
            Measure the voltage to ground of the following points of interest:
            I2C_PWR_SDA
            I2C_PWR_SCL
            • bilel
              • Mar 2019
              • 31
              You replace t2 chip ! was have serial number !
              • PITERPENY
                • Jul 2023
                • 463
                • Ukraine
                #27
                I swapped the BIOS chip with the serial number from another MacBook, same problem
                • mon2
                  • Dec 2019
                  • 14726
                  Post #25
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    #29
                    I've just swapped T2 from one a1989 (that was not working - burned display pin in cpu). To another a1989 that was icloud locked. Nothing else just T2
                    First thing you have to do is boot to DFU and connect to another macbook with Apple configurator 2. Device must be shown as apple device (under DFU in apple configurator, if it shows DFU but under is Unknown device that is probably because T2 is bad or bad soldered)
                    second Revive (that can end with error - but you need to have apple logo at least on the macbook)
                    third when it finished (at least for me it was so) macbook started in DFU and i go to Restore via apple configurator (whole process until padlock)
                    then macbook started that no OS installed (flashing folder icon). I've restarted it in internet recovery (CMD + Option + R) reinstalled os and it's working.
                    everything except fingerprint (i have to find correct fingerprint that was married with that T2)
                    • MyronViegas
                      MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                      by MyronViegas
                      Hey guys,
                      I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                      Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                      10-06-2025, 08:45 AM
                    • martyjelen
                      Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
                      by martyjelen
                      I need help with Macbook A1989. It stuck at 5V / 5mA.
                      I already do some measurements https://logi.wiki/index.php/CD3215_Bootup_Sequence
                      PP20V_USBC_XB_VBUS - 5V
                      PP3V3_UPC_XB_LDO - 3V
                      PP1V8_UPC_XB_LDOA - 1.8V
                      PP1V8_UPC_XB_LDOD -1.8V
                      PP1V1_UPC_XB_LDO_BMC - 0V
                      It's the same on all CD3215. There is no signs of corrosion or something like that.
                      What should I check?
                      Thanks for help.
                      Martin
                      05-11-2023, 02:38 AM
                    • nosinformatica
                      Macbook Pro 13'' - A1989 stuck at 5v
                      by nosinformatica
                      Preface : My primary job it's not repairing logic board, so please excuse me.
                      The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                      I'have read that these mac have two CD3125 in daisy chain.
                      How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                      09-29-2023, 06:29 AM
                    • Ledgurra
                      MacBook Pro A1425 it doesn't turn on
                      by Ledgurra
                      hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                      thank you all
                      11-09-2025, 06:07 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
