egl 11qf6 tablet
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    egl 11qf6 tablet
    Hi im trying too find a replacement battery for the above tablet i have uploaded a picture of the exact battery thats fitted as limited on space im sruggling too find a replacement its a 3 wire battery (what is the purpose of the third wire as i have found some 2 wire versions) can anyone help me find a link many thanks guys
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Edit Think i may of found a battery that will do the job pity its 3.4 mm though just trying too work out if will fit in the housing XINJ 3.7V 5000mAh 18.5Wh Polymer Rechargeable Li Lipo Battery 3490120 Thermistor 3 Wires For GPS Portable Baby Monitor Tablet PC - AliExpress
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mferna14
      MacBook Air A2681 battery problem after Screen Replacement
      by mferna14
      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
      12-06-2024, 08:10 PM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • NConstantinou
      LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
      by NConstantinou
      Dear all,
      i have the above laptop which had a problem with battery. i replaced it with a compatible one..
      the laptop DOES NOT POWER ON..
      with it old battery it does power on.
      i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
      when i shutdown the laptop does not power on.
      does anyone have any solution!
      when is not power on the usb c voltage tester shows 5v 1.3A
      when i disconnect battery and power on and then connect battery the tester...
      12-10-2024, 04:52 AM
    • PITERPENY
      Macbook A1707 820-00928 battery replacement
      by PITERPENY
      brought in a working MacBook for battery replacement (swelled up). After replacing the battery it stopped turning on. tried connecting the old battery without changes. consumption with the battery connected and without the battery is the same 5v\0.200a on all 4 ports. replacing 9239 did not help
      04-20-2025, 03:22 PM
