820-02098 not charging help me
  • Joyoungjae
    • Oct 2020
    • 23
    • south korea
    Dear friends
    Merry Christmas
    I came out to work briefly today as well.
    I'm not unhappy haha
    I received a MacBook Pro A2442 water damage.
    When I connect the charger, it keeps turning on and off and the voltage indicator blinks.
    When the charger is removed, the power turns on and remains on with the remaining charge in the battery.
    After submersion cleaning, the submerged Q5240 and UG800 (elc180 power ic?) were replaced.
    Still, the symptoms are the same, so I'm trying to replace the charging IC, but I'm curious if it's meaningful.
    If that's correct, the charging IC (u5200) I have is ISL9240HI, but the chip installed in the MacBook in question is ISL9240HIB3.
    I wonder if I can just use it.
    Thank you for reading and have a nice Christmas
  • mon2
    • Dec 2019
    • 14366
    Hello. Merry Christmas - ours is later tonight.
    For now, do not worry about this very tiny WLCSP packaged device. It is not fun to replace and may raise more issues than the current fault on the logic board. Unless 100% confident this device is faulty, do not mess with it. The part is available on Aliexpress.
    Suggest:
    1) purchase a USB Type C meter and insert it between your power adapter and this logic board. The digital display on the meter will offer details on the power delivery contracts being selected by the logic board. For a normal boot and charging process, the power delivery contract should be @ 20V (not the power up default of 5 volts). If you have this tool - do share the details of the display.
    2) Remove the battery. Use only the power adapter. Carefully measure the voltage to ground @ F5200 or F5201. What is the voltage measurement? Is it power cycling? At this point of test, the ISL9240 is the producer of this power rail in that the power delivery controllers have instructed the external power adapter to spit out 20V. Then this regulator acts like a buck regulator (high input voltage to lower downstream voltage) and should output a voltage in the ~12 to 13 volt range. The exact voltage is important to know to determine at which stage of the power on cycle the logic board is in. If this voltage is not stable, then this leg of the circuit needs to be reviewed.
    • Joyoungjae
      Joyoungjae commented
      Editing a comment
      !!!!!- thank
  • Joyoungjae
    • Oct 2020
    • 23
    • south korea
    감사하다
    • Joyoungjae
      • Oct 2020
      • 23
      • south korea
      Suggest:
      Thank you so much for your kind reply.
      First of all, I skipped a lot of things and asked questions.
      To be precise, I took a voltage meter and plugged the charger into my MacBook. It switches well up to 20v, but the voltage switch turns off, turns on again, and repeats turning off again when it shows 20v.
      So, if I remove the charger, it boots normally. Currently, it turns on because there is still charge left, but if it is discharged, it will not be charged and will not be used.
      So I short-circuited the battery and plugged in the charger with only the logic board in place, and it stayed at 20v just fine. In conclusion, pulsing symptoms appear when the charger is connected.
      I'm not good at English, so I use a translator...
      I'm worried that what I'm trying to say will be heard well.
      Anyway, thank you, friend. What do you think?!
      • mon2
        • Dec 2019
        • 14366
        Ok. Issue could be a leaky mosfet in the power path to PPBUS_AON. That is, either the power adapter OR battery must power PPBUS_AON - not both.
        Remove all power / disconnect the battery. Meter in resistance mode.
        Measure the resistance of the mosfet @ Q5265 (battery mosfet)
        Measure:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement. We are checking for a low resistance which usually means the mosfet is defective.
        • Joyoungjae
          • Oct 2020
          • 23
          • south korea
          Measure:
          hellio sir
          I'm not sure if I understand it correctly, but if you measure Q5265 from 1, 2, 3 to 5, you get 0.710m ohm.
          And if you take 4 to 5, it is measured as 15.42m ohm.
          Is it true that you want me to take a picture like this?
          After measuring 1, 2, 3 to 4,
          It comes out at 5.7 m ohm!!
          I have the same board, so I took a picture of another board and got 11.2m ohm. Is this the problem??​
          • mon2
            • Dec 2019
            • 14366
            Perform the same measurements on the good board for Q5265 so we can compare. Post each measurement. Only the first reading looks low (1-2-3 and 5-6-7-8).
            • Joyoungjae
              • Oct 2020
              • 23
              • south korea
              thank you sir
              When taken on a good board, only 1, 2, 3 to 4 show different values.
              Are you talking about measuring from ground to point?
              I recorded the resistance values in the MOSFET using 1, 2, 3 points and 4 points.
              Did I understand it well?​
              • mon2
                • Dec 2019
                • 14366
                No, not to ground. Just across the mosfet pins. The good board is also ~700k ohms for source to drain pins?
                how did you short circuit the battery to run the logic board? Bypassed q5265?
                • Joyoungjae
                  • Oct 2020
                  • 23
                  • south korea
                  sir
                  Just in case, I measured it again and this time the resistance value was the same as the normal board. Is my tester weird?
                  Yes and it outputs ~700k ohm
                  • Joyoungjae
                    • Oct 2020
                    • 23
                    • south korea
                    no
                    Turning on the MacBook works normally when the charger is unplugged, so you can boot it up without the charger connected.
                    Sorry, I guess I misrepresented something in the question.
                    Can I ask you a question via message? I'm worried about whether I understand what sir is saying.
                    • mon2
                      • Dec 2019
                      • 14366
                      Is the charger the original from Apple? What is the power rating of this adapter? If the power adapter is under rated, it will power cycle.
                      if you remove the battery and use only the power adapter, what is the voltage of PPBUS_AON?
                      do you still have a power cycling? Concerned about the replaced dual mosfet. Soldered ok?
                      Best to continue the investigation here in this forum so other techs can assist. About to watch some Netflix. Ps: my brother is obsessed with the many tv series from South Korea on Netflix. He claims much better writing than Hollywood.
                      • Joyoungjae
                        • Oct 2020
                        • 23
                        • south korea
                        First of all, we've completed the repair.
                        Sir's kind explanation made me take a slow look at what I didn't see.
                        As a result, I rediscovered what I missed from the beginning.
                        I found a fine short on LDO circuit lines around cd3217.
                        It made me realize again by tracing back from the UG800 where corrosion was first seen due to flooding.
                        When I do repairs, I get stuck in one place and miss it like this, but the things you advise me felt like I was repairing together and it helped. Thank you.
                        ​P.s / Oh really? I happened to watch Concrete utopia last week and it was fun
                        • Thomasraud
                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                          by Thomasraud
                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                          QUOTED
                          -It works on charger (without battery connected-only charger)
                          -It works on battery (without charger connected-only battery)
                          -& it also works when plugged in battery & charger, but it's not charging the battery
                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                          and..
                          QUOTE
                          The IC cannot maintain the input current level
                          06-28-2022, 06:47 PM
                        • Scoff
                          HP Probook 470 G4 - Power and Charging Problem
                          by Scoff
                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                          07-03-2023, 09:28 AM
                        • SluggerB
                          Help with trying to fix phone that is not charging (Pics inside)
                          by SluggerB
                          I have two TCL A30 phones.
                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                          08-12-2024, 08:11 AM
                        • abrahim110
                          [Help Needed] Acer Aspire 5 A517-52G – Removed Onboard RAM, Now Working But Battery Not Charging
                          by abrahim110
                          🧵 [Help] Acer Aspire 5 A517-52G – Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                          I have an Acer Aspire 5 A517-52G-53NB laptop.
                          The onboard (soldered) RAM was faulty, so I physically removed the chip.
                          I also successfully modified the BIOS using the SPD Removal Tool – the laptop now boots fine and works with an 8 GB DDR4 SO-DIMM installed.
                          ✅ System status:
                          • BIOS mod is done (SPD removed)
                          • Laptop boots to Windows normally
                          • RAM is detected and stable
                          ❌ Problem:
                          The battery is not charging:
                          • Power adapter
                          08-06-2025, 06:15 AM
                        • master3112
                          by master3112
                          07-29-2025, 01:55 PM
