Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
  • zlr8r
    • Feb 2023
    • 107
    thanks, where should i be looking next to locate fault ?
    • zlr8r
      • Feb 2023
      • 107
      any recommendations for next step in repair ? replace charging IC, and maybe RAM controller IC ? thanks
      • zlr8r
        • Feb 2023
        • 107
        scrapped the laptop as I couldn't pinpoint the exact problem component. Thanks to all those who tried to help.
        • zlr8r
          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
          by zlr8r
          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
          cheers
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          MOBO: RO 15 17 WHL 2GB MB / 18706-2
          Attached;
          1. My saved bios using a programmer
          2. Dells Bios updater .exe (v1.16)
          3. Dells Bios recovery file
          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
          5. Image of ME...
          12-18-2023, 03:08 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • iulik17d
          Intel Arc A380 videocard power limit remove - BIOS needed
          by iulik17d
          Hello everyone!
          The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
          The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
          01-10-2025, 02:33 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • LimesKey
          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
          by LimesKey
          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
          10-17-2025, 05:33 PM
