Lenovo L15 Gen2 Not Booting
  • chick0n
    • Mar 2017
    • 17
    My L15 doesnt power on. When I connect charger, charging light lights up, and Power LED blinks 3 times, then nothing... When I press power button nothing... I tried everything, remove batteries, checking fuses...
    Maybe BIOS is corrupt?
    Mainboard is: NM-D271 HL4A0 / HL5A0 REV2.0
  • chick0n
    • Mar 2017
    • 17
    Bios dump
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria šŸ‡§šŸ‡¬
      Originally posted by chick0n
      Bios dump
      Do not post a bios dump in this section please.
      Reminder: rules and organization of this section
      https://www.badcaps.net/forum/troubl...f-this-section
      BIOS guides, methods, resources and tools -> https://www.badcaps.net/forum/troubl...rces-and-tools
      All bios related requests/replies goes to dedicated sub-forum only -> BIOS Requests ONLY!
      All bios related requests/replies rules are posted here -> RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*
      Become a Badcaps supporter
      Thanks to all supporters.​
      • chick0n
        • Mar 2017
        • 17
        sorry
        • mon2
          • Dec 2019
          • 13833
          Carefully measure the voltage to ground of each pin on dual dcin mosfet at PQ0204. Post each measurement. Schematics are available in the schematics forum.
          • chick0n
            • Mar 2017
            • 17
            Pin1 0V
            Pin2 0.443V
            Pin3 0V
            Pin4 0V
            • mon2
              • Dec 2019
              • 13833
              You do not have the power coming from the external power adapter (based on the measurement on pin # 2 of this dual mosfet).
              Carefully measure the voltage to ground at both sides of the fuse @ F6001.
              • chick0n
                • Mar 2017
                • 17
                I testet without poweradapter, just with batterie. I will test again tomorrow, with adapter.
                • chick0n
                  • Mar 2017
                  • 17
                  Now measured with batterie and power adapter (batterie is charging)
                  Pin1 16.26V
                  Pin2 20V
                  Pin3 0V
                  Pin4 1.767V​
                  When I connect the power adapter, the power led blinks three times. When i press power button, nothing happens.
                  When I disconnect cmos batterie and connect power adapter the power led stays on, fan spins up, cpu gets warm, but no picture. sometimes I even get a error code over speakers.
                  • mon2
                    • Dec 2019
                    • 13833
                    Connect the power adapter. What is the voltage to ground at capacitor c6002?
                    what is the voltage at the fuse f6001?
                    • chick0n
                      • Mar 2017
                      • 17
                      c6002 20V
                      f6001 0V (Fuse is good)
                      • chick0n
                        • Mar 2017
                        • 17
                        It works:
                        https://www.badcaps.net/forum/troubl...n2-not-booting
                        SD-Card Controller was burned, and BIOS was Corrupt.
                        • madrali
                          lenovo e15 gen2 bios ? problem
                          by madrali
                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                          20TD-50S0KU00
                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                          06-16-2025, 12:06 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • grimacelord
                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                          by grimacelord
                          Hello there.
                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                          History:
                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                          I searched for this error online and discovered...
                          03-15-2023, 03:29 PM
                        • jendkkd jeje
                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                          by jendkkd jeje
                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                          10-11-2024, 03:12 PM
                        • mximiliandz
                          help bios lenovo ideapad s145-14iil type 81w6
                          by mximiliandz
                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                          06-20-2025, 06:50 AM
