Lenovo L15 Gen2 Not Booting
  • chick0n
    • Mar 2017
    • 22
    My L15 doesnt power on. When I connect charger, charging light lights up, and Power LED blinks 3 times, then nothing... When I press power button nothing... I tried everything, remove batteries, checking fuses...
    Maybe BIOS is corrupt?
    Mainboard is: NM-D271 HL4A0 / HL5A0 REV2.0
  • chick0n
    • Mar 2017
    • 22
    Bios dump
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria šŸ‡§šŸ‡¬
      Originally posted by chick0n
      Bios dump
      Do not post a bios dump in this section please.
      Reminder: rules and organization of this section
      https://www.badcaps.net/forum/troubl...f-this-section
      BIOS guides, methods, resources and tools -> https://www.badcaps.net/forum/troubl...rces-and-tools
      All bios related requests/replies goes to dedicated sub-forum only -> BIOS Requests ONLY!
      All bios related requests/replies rules are posted here -> RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*
      Become a Badcaps supporter
      Thanks to all supporters.​
      • chick0n
        • Mar 2017
        • 22
        sorry
        • mon2
          • Dec 2019
          • 14673
          Carefully measure the voltage to ground of each pin on dual dcin mosfet at PQ0204. Post each measurement. Schematics are available in the schematics forum.
          • chick0n
            • Mar 2017
            • 22
            Pin1 0V
            Pin2 0.443V
            Pin3 0V
            Pin4 0V
            • mon2
              • Dec 2019
              • 14673
              You do not have the power coming from the external power adapter (based on the measurement on pin # 2 of this dual mosfet).
              Carefully measure the voltage to ground at both sides of the fuse @ F6001.
              • chick0n
                • Mar 2017
                • 22
                I testet without poweradapter, just with batterie. I will test again tomorrow, with adapter.
                • chick0n
                  • Mar 2017
                  • 22
                  Now measured with batterie and power adapter (batterie is charging)
                  Pin1 16.26V
                  Pin2 20V
                  Pin3 0V
                  Pin4 1.767V​
                  When I connect the power adapter, the power led blinks three times. When i press power button, nothing happens.
                  When I disconnect cmos batterie and connect power adapter the power led stays on, fan spins up, cpu gets warm, but no picture. sometimes I even get a error code over speakers.
                  • mon2
                    • Dec 2019
                    • 14673
                    Connect the power adapter. What is the voltage to ground at capacitor c6002?
                    what is the voltage at the fuse f6001?
                    • chick0n
                      • Mar 2017
                      • 22
                      c6002 20V
                      f6001 0V (Fuse is good)
                      • chick0n
                        • Mar 2017
                        • 22
                        It works:
                        https://www.badcaps.net/forum/troubl...n2-not-booting
                        SD-Card Controller was burned, and BIOS was Corrupt.
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • madrali
                          lenovo e15 gen2 bios ? problem
                          by madrali
                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                          20TD-50S0KU00
                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                          06-16-2025, 12:06 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • grimacelord
                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                          by grimacelord
                          Hello there.
                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                          History:
                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                          I searched for this error online and discovered...
                          03-15-2023, 03:29 PM
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
