Msi p75 Problem with de screen
  • shaggymen
    • Nov 2023
    • Spain
    Hello everyone! I have an MSI Creator P75 9sd laptop that after making a short circuit, a component identified as L13 burst. I think it is an inductor, model 0603 but I don't know what NH or uH it has. How can I find out that value, and if it's not possible, does anyone know how I can test it bit by bit without destroying more components. I leave you photos so you have more information. Thank you all
    Edit: I forgot to tell you, the laptop does not show a signal on the screen but it does, however, show it through the HDMI connector. The laptop works perfectly via HDMI, however the native screen is black.
    I have checked the continuity in other components called Lx where x is a number, and connecting the terminals of my tester to the terminals of the component it beeps indicating continuity so I understand that it is an inductor.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    You can even jumper the coil pads for test purpose. First clean the area and check resistance to GND on both the pads of L13
    • mmccomputer
      problem with replacing lcd screen
      by mmccomputer
      I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
      otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
      If anyone has any information on the subject...
      12-15-2024, 03:44 PM
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • Chrissygizmo
      Sony KD-55XG9505 lines on screen problem
      by Chrissygizmo
      Hello again everyone,
      This is my latest mission, to try getting this Sony tv back to normal working order…
      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
      02-19-2025, 11:31 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
