Alienware M17-R1, Windows 7, BSOD
  • johnboy1313
    • Nov 2012
    • 1959
    I'm hoping you guys can help me. I recently traded a TV for this laptop. It is running Windows 7 but frequently shuts down to a blue screen of death. I'm not a laptop guy at all. I've searched the net, but can't find anything that works, and I only know enough to be dangerous. I've received a ton of help from the TV gurus over in the TV forum, so I'm hoping one or more of you can help me out.
    It crashes almost every time I use Google Chrome. The screen gets a bunch of lines and then BSOD.
    It crashes less frequently with Internet Explorer, but when it does, it seems to happen most of the time when trying to stream video.
    It doesn't seem to crash at all, or at least not very often, with Firefox.
    I've read that it could be a driver issue or a hardware issue, or a combination of both, but like I said, I'm not a computer guy so I don't really know how to determine what's good and what's bad.
    Thanks in advance for the help.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Alienware M17-R1, Windows 7, BSOD
    Do this: http://pcsupport.about.com/od/window...-windows-7.htm then tell us the numbers that appear on the BSOD, or snap a pic of the screen.
    A working TV? How boring!
    • johnboy1313
      • Nov 2012
      • 1959
      It'll run ubuntu all day without crashing, but I can't stream from the Dish TV Sling Player with ubuntu. If I could figure out how to do that, I might not even use Windows anymore.
      • alihomee
        • Dec 2012
        • 1575
        • malaysia
        if your laptop using a gpu then that one should be the cause of problem and if u want to conform that its a driver problem then download the latest driver from dell website and install it
        • johnboy1313
          • Nov 2012
          • 1959
          OK, if I can get it to crash, I'll post a pic. It'll take a second. Thanks.
          • johnboy1313
            • Nov 2012
            • 1959
            OK, so now it's making a liar out of me. I'll post a pic as soon as I can get one.
            • johnboy1313
              • Nov 2012
              • 1959
              This is a pre-Dell laptop. They claim they don't support the older Alienware. It's ran all day with no issue
              • johnboy1313
                • Nov 2012
                • 1959
                It finally crashed on me.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  That's typically a memory error. Run bootable memtest and see if it reports any trouble.
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Is that the Windows memory test or a program by another supplier? Windows' memory test doesn't show any errors.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      i use the free version of this not sure what the others use
                      http://www.memtest86.com/download.htm
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        This. You can also find it packaged with most Linux distros and on Hiren's Boot CD.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          I ran the test and went up to get ready to go out tonight. When I came back windows was booted. I expected there to be a message of some kind telling whether the memory was good or not. I'm running it again but I don't know if the test will be done before I go out. Here's a pic. Would running 1 gig and 2 gigs of memory side by side be a problem? I've always thought you had to use matched sticks.
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            That means it crashed and rebooted during memtest. 100% sure there's nothing overheating? Bad memory can also cause rebooting before it has a chance to display the errors.
                            It's usually not a problem to run unmatched sticks, but depending on speeds and timings, they may cause issues with certain configurations.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              A BSOD sounds like overheating, especially AMD CPU-based laptops.
                              -> Strangely, Windows gave a BSOD on a laptop that didn't have an overclocked CPU!
                              Despite that even 100C shouldn't cause an error when not overclocked!
                              -> OS errors are not typical with stock CPU core clocks!
                              And combined with lines, sounds like a PSU failure, bad caps or bad solder joints.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                That's an intel CPU there.
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  It looks more like a power issue.
                                  Arc A770 16 GB
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    No memory errors found with Memtest86. RJARRRPCGP, can you give a little more detail on checking the PSU?
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      It's either the power adapter or on the board.
                                      Arc A770 16 GB
                                      • spleenharvester
                                        • Mar 2010
                                        • 902
                                        Look at the artifacting on the BSOD screenshot. That looks like a GPU fault to me.
                                        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                        • jheunne
                                          asus ux425I help only loading windows bsod
                                          by jheunne
                                          i have here asus ux425i problem won't boot on windows even installing new clean windows it just loading windows long time then turn to bsod even the installer unable to access on startup. new ssd new installer same status. i already flash bios no luck have anyone encounter this problem
                                          02-03-2025, 11:28 PM
                                        • dhibubabu
                                          Alienware Keyboard Not Working In Windows
                                          by dhibubabu
                                          Alienware x15 R2
                                          Service Tag: 8XCW5M3
                                          Motherboard no: LA-L611P
                                          Keyboard will work properly in Bios settings _we can press F2 and all keys working in bios
                                          after windows load keyboard will not work
                                          no caps lock light,_no response._keyboard backlight is working..
                                          tested with new keyboard - same issue
                                          installed all drivers from official site
                                          tried with windows 10 & windows 11
                                          if anyone know this solution, please share your experiences
                                          thanks you
                                          10-31-2023, 03:16 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • angel35
                                          Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
                                          by angel35
                                          An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
                                          (like below picture)
                                          What can cause somethimes ok, somethimes not good ACPI state? Really strange
                                          If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
                                          Wong Bios IC? Power problem?
                                          Wrong status:
                                          Good status somethimes:
                                          07-27-2024, 04:04 PM
                                        • kuraimangetsu
                                          PRECISION 3510 BSoD when installing windows
                                          by kuraimangetsu
                                          Hi.
                                          I received a dell precision 3510.
                                          works fine on bios
                                          but i always get a BSoD when installing windows 7-10-11 64-86 uefi or legacy.
                                          tried changing RAM and swap slots.
                                          changed the M.2 to new one too.
                                          tried like 15 different OS! same thing! still getting BSoD when installing windows.
                                          tried hirens BOOT, but still getting system crash after two minutes.
                                          even tried linux still getting crash while installing
                                          tried updating bios and downgrading it same thing
                                          is reflashing new bios straight to the IC is...
                                          01-04-2023, 11:42 AM
