asus ux425I help only loading windows bsod
  • jheunne
    • Sep 2022
    • 63
    • philippines
    i have here asus ux425i problem won't boot on windows even installing new clean windows it just loading windows long time then turn to bsod even the installer unable to access on startup. new ssd new installer same status. i already flash bios no luck have anyone encounter this problem
  • klynstronic
    • Jun 2022
    • 45
    • españa
    I had a similar problem on an Asus board and it was the CPU not working properly. It could be an internal problem or incorrect power supply. It doesn't mean that it is the case but perhaps the error lies there.​
    • pc_okay
      • May 2022
      • 244
      • FRANCE
      It could be a lot of things. First share us photos of your BSOD please. Tell us if it the same error code on Bsod, and tell us error codes or take photos…
      thanks!
      • jheunne
        • Sep 2022
        • 63
        • philippines
        here is the screen shot
        i already flash bios from 307 to 302 and clean install new windows and new ssd no luck still the same problem
        • pc_okay
          • May 2022
          • 244
          • FRANCE
          After fresh install can you start Windows at least once Time before it crash?
          Did you try another installation media 11/10, other version of Windows…
          Try with minimum hardware just motherboard and charger, remove battery, wifi card, battery, keyboard, mouse screen (if This laptop can boot externally) use usb mouse/keyboard.
          Reinstall and if it works, reinstall part one by one until it crashed.
          • Aliencomputres
            • Aug 2019
            • 218
            • România
            try to test memory/ram with memtest.
            • jheunne
              • Sep 2022
              • 63
              • philippines
              i can't start windows normally even installing fresh windows media same status logo with circling at the bottom. all are built memory ram and wifi card. i can only go to bios setup i tried to restore defaults settings still the same. as i go to sata config setting mode to ahci when i tried to restore settings to default the sata config for ahci does not display when restart it it display ahci.
              • Aliencomputres
                • Aug 2019
                • 218
                • România
                Remove ssd/hdd and run MemTest86-Self-booting USB-No O/S required.
                https://www.memtest86.com/
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3628
                  • slovakia
                  pnp hang up. some chip must be stuck. try to disable everything not needed for run in bios - audio, LAN, wifi, ...
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    There is no fixed solution for BSOD issues.
                    Sometimes resoldering/replacing vcore ic along with mosfets solves it(specially on lenovo).
                    Sometimes reballing the cpu fixes it.
                    Onboard ram can be the culprit.
                    So there are multiple reasons for BSOD and in few cases i couldnt solve it even after following all the above steps.
                    If you have a bga rework station, try to reflow the SOC. Dont attempt to do so with hot air gun.
                    • alleotechno
                      • Oct 2023
                      • 16
                      • Malaysia
                      Hi, i am facing the same issue like you, cannot install fresh windows, i cannot do the mem test or hardware test it will BSOD and also i cannot update windows if installing update restart require it will BSOD, except play around in BIOS, im able to clicking anywhere i want inside bios menu without any BSOD error. What im going to do is, i have another laptop (Second laptop) and use it for the fresh installing windows and setup the Cpu software presure include schedule task to make sure windows auto start running + cpu presure and put SSD it back into the BSOD laptop then i use like normal, but my 1 core in task manager graph will full loaded 100%. I use gaming center to centralized the cpu utilization.
                      Hope this step can help you. I try to check the mosfet voltage BQ chip, but i am still (Failed) to get my mobo diagram.
                      Here my link | https://www.badcaps.net/forum/troubl...presure-on-cpu
                      Last edited by alleotechno; 02-07-2025, 04:20 AM. Reason: Share my (Link) problem to other people and repair grammer.
                      • jheunne
                        • Sep 2022
                        • 63
                        • philippines
                        i think the problem is the connection lines of my nvme when i plug in new or old i turns hot my ssd nvme so when check in bios no detection sometimes it detects but failed to load hope can someone upload boardview
