List of pin compatible Laptop ICs
This is a sticky topic.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #61
    Re: List of pin compatible Laptop ICs
    Any swap for SMSC KBC1091-NU?
    A working TV? How boring!
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      #62
      ISL6251 can be changed with M124/G5209
      • bindiou
        • May 2015
        • 11
        • France
        #63
        hi
        is RT8206A compatible with RT8206L ?
        i found same pins layout
        ty
        • Agent24
          I see dead caps
          • Oct 2007
          • 5081
          • New Zealand
          #64
          Originally posted by bindiou
          hi
          ty
          I looked at the datasheets and they seem 98% the same... but I noticed a few things like:
          RT8206L\M has "4700ppm/°C RDS(ON) Current Sensing" which the A\B does not seem to... (not sure how much that matters)
          The A\B have "Internal Soft-Start with 5 Steps Current Limiting and
          Soft-Discharge" while the L\M has a 1-step linear ramp up (See Power On in Short Circuit graphs in datasheets)
          Also, L\M have internal Under-Voltage 0.55 x VREF while in A\B it is 0.7 x VREF
          I also saw some slightly higher switching frequency on some graphs (extra 50kHz for L\M)
          So while everything else is very similar, I don't know what (if any) problems these minor differences may cause in some circumstances.
          Personally, without knowing the exact nature of the circuit the part was used, I would use only the same type as originally used in the circuit.
          It comes down to "try it and see what happens" or stay safe and use what was already there and which you know will work. Do you really want to solder a tiny QFN twice because you got the wrong variant chip?
          Since both models are in active production it should not be an issue to get whichever you need.
          -David VanHorn
          • bicalov
            • Nov 2014
            • 294
            • Netherlands
            #65
            Looking for an equivalent for the Mosfet FDC655BN in order to find it from an old board
            Via Google I found SST6N3LLH6 and NTGS4141NT1G but no luck.
            Anybody know a solution? I read on this forum, that you can use any Mosfet with the same specs.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5081
              • New Zealand
              #66
              Yes you can use different parts with the same ratings usually, although it might be easier to just buy the one you want here: http://nl.farnell.com/fairchild-semi...t-6/dp/2101405
              -David VanHorn
              • bicalov
                • Nov 2014
                • 294
                • Netherlands
                #67
                Thank you for the response and the link, but they sell to companies.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5081
                  • New Zealand
                  #68
                  Are you sure? I buy from the New Zealand version (nz.element14.com) and they sell to individuals. I was supposed to enter a company name when signing up, but I just used my name and have had no problems ordering from them for years.
                  You might also try http://www.rs-components.com/index.html and select the site for your country.
                  Otherwise, try eBay.
                  EDIT: Just checked, seems they say "If you are an individual consumer, you should keep in mind that there is a minimum order value of € 50 applies to orders placed over the Internet."
                  That sucks for you.. in NZ here it's only $10 minimum and $45 for free shipping.
                  -David VanHorn
                  • bicalov
                    • Nov 2014
                    • 294
                    • Netherlands
                    #69
                    thks for your help,
                    I found one with no minimum and €6,95 shipping costs
                    https://www.conrad.nl/nl/fairchild-s...8HAQ&WT.srch=1
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1490
                      • portugal
                      #70
                      bq24717 compatibility ?
                      • bicalov
                        • Nov 2014
                        • 294
                        • Netherlands
                        #71
                        Not quite.
                        FDC655BN= Single N-Channel, Logic Level, PowerTrench ®MOSFET
                        BQ24717= Battery Charger ICs
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5081
                          • New Zealand
                          #72
                          Not quite.
                          I think he's asking for equivalents for the BQ24717, which is what this thread was supposed to be about - listings of substitute parts.
                          -David VanHorn
                          • bicalov
                            • Nov 2014
                            • 294
                            • Netherlands
                            #73
                            I am sorry Highpulse, I reacted to fast as if it was my own tread.
                            But of course this is for equivalents as my question was originally too.
                            Maybe I can make it up with the guide.
                            • snackpol
                              • Oct 2013
                              • romania
                              #74
                              max8731 = isl 88731
                              • masud
                                • Jul 2011
                                • 317
                                • Bangladesh
                                #75
                                what is the alternate of ISL 6260
                                • masud
                                  • Jul 2011
                                  • 317
                                  • Bangladesh
                                  #76
                                  RT8203 = Max8734
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    #77
                                    does anyone know compatibility with MAX17005ETP+ for substitute?
                                    Im Back... sort of...
                                    • Djosla
                                      • Dec 2012
                                      • 246
                                      • Montenegro
                                      #78
                                      Today i have replaced intel gm45 chipset with gl40 on lenovo g550...Laptop did not have video...Now works ok...
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1490
                                        • portugal
                                        #79
                                        bicalov , put the mosfet name on google , chek if its N or P channel , or DUAL P or N
                                        then , replace with a similar , if its for main b+ line , 8884 - 4800b for ex can be used , if its a N channel for ex.
                                        • age80
                                          • Jun 2013
                                          • 55
                                          • Greece
                                          #80
                                          any equivalent for P2808B0 ???
                                          http://www.datasheetbank.com/datasheet/ETC/P2808B0.html
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
