List of pin compatible Laptop ICs
This is a sticky topic.
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    #221
    Re: List of pin compatible Laptop ICs
    AFAIK:
    Suffix Code B1 on NPCE985PB1DX a few pinout have signals/voltages 1.8V only, BE AWARE with code suffix A0 on NPCE985PA0DX most likely have signals/voltages 3.3V.
    Note:
    Need confirm from other experience Techs here.
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      #222
      Good day guys. I just need to confirm if ic PM6686TR and PM6686 are the same? Coz I want to substitute it for this sn0608098. it takes 20 plus day to order the correct replacement. Thanks
        • 21996
        PM6686 and PM6686TR are the same, the TR means Tape and reel ,its just the type of packaging that the IC`s are supplied in .
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          #224
          anybody knows replacement for RT8248A ?
          • classicandy
            • Apr 2018
            • 309
            • Nigeria
            #225
            Please, does anyone know the equivalent I.C. for BQ24715?
            Thanks in advance.
            • charafmak77
              • Oct 2017
              • 81
              • jijel
              #226
              • GITs
                • Mar 2019
                • Cameroon
                #227
                Originally posted by pavel.kinc
                BQ24747 = BQ24745 = ISL88731C HRTZ - test all OK
                Thank a million times Bro
                • aliiash
                  • Jun 2019
                  • 99
                  • england
                  #228
                  • karimreza2
                    • Mar 2018
                    • 23
                    • Bangladesh
                    #229
                    Re: List of compatible Laptop ICs
                    isl 95836 and max 8778e compatible with wich ?
                    • yavuz5233
                      • Aug 2018
                      • turkey
                      #230
                      https://docs.google.com/spreadsheets...it?usp=sharing
                      • f-bone
                        • May 2013
                        • 96
                        • Greece
                        #231
                        Originally posted by Weelcup
                        Hi again guys
                        I just decided to replace and check.. and booom it is working!
                        just wanted to share the info with you... all the best everybody
                        thanks man!
                        • peste
                          • 13661
                          • ROMANIA
                          #232
                          HI...Voltage controller "39 = 3D" has the equivalent? I didn't find anything about him.
                          thank you..
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            #233
                            "39=" → Richtek RT7291AGQUF
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              #234
                              Today, I replaced Max17020 by RT8206B. It worked fine after this replacement in the same circuit.
                              • canali
                                • Oct 2014
                                • 195
                                • turkey
                                #235
                                Thk's
                                • red_raian
                                  • Aug 2011
                                  • 14
                                  #236
                                  MAX17411 what is compatible ic?
                                  • caspian
                                    • Oct 2015
                                    • 1591
                                    • Laptop
                                    #237
                                    Since MAX17411 has many pins, no other IC seems to be compatible to it. It would be better to buy exactly the same MAX17411 model with the same number of pins.
                                    • red_raian
                                      • Aug 2011
                                      • 14
                                      #238
                                      4957agm comptible mosfet?
                                      • MD Arshad
                                        • Feb 2019
                                        • 8
                                        • India
                                        #239
                                        hi
                                        can any one advise if TPS51285 is compatible replacement for TPS51275?
                                        thanks in advance
                                        Can anyone give meIt8518e datasheet
                                        • luna69
                                          • Jul 2019
                                          • 9
                                          • Philippines
                                          #240
                                          any equivalent voltage regulator ic for LV5028AGQV? QFN 5x5 40
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
