Lenovo SL510 Keyboard issue - bad unidentified resistor
  • Monument
    • May 2011
    • 40
    • Estonia
    Hello, recently got a Lenovo SL510 laptop. The laptop had a coffe spill, I cleaned it up, put it back together, the keyboard worked just fine. After the laptop had not been used for two weeks, the keyboard stopped working. So I took it apart again and removed the stickers on the motherboard to find any residue. What I found was bad, the coffe got under one sticker and was already "eating" the components, I cleaned the board with a toothbrush and alcohol and found a resistor that was not working and looked very bad, I can't identify the value of the resistor, or maybe it's a small SMD diode?
    The small red mousethingy is working fine, also external keyboard is working. I am out of ideas guys.
    Maybe someone can help me find a schematics of the motherboard, Monument.
  • Monument
    • May 2011
    • 40
    • Estonia
    Re: Lenovo SL510 Keyboard issue - bad unidentified resistor
    I can't find the schematics anywhere.
    • robrock1
      • Jul 2013
      • 129
      • Ghana
      hello, is this the schematic for it?
      • Monument
        • May 2011
        • 40
        • Estonia
        No sir, it's not. When I check for an example "R345", the values are different from the ones in this pdf file.
        Here's the image of this area.
        • Monument
          • May 2011
          • 40
          • Estonia
          I am out of ideas.
          • Francisco.s
            • 686
            • Spain
            Originally posted by Monument
            I am out of ideas.
            Clean this zone of PCB, and post new photo.
            • Monument
              • May 2011
              • 40
              • Estonia
              I took out the resistor, it was very oxydated, couldn't tell the value, even the surrounding PCB is a bit damaged.
              • Francisco.s
                • 686
                • Spain
                Are Q17 and U26 in contact through any of its pins?
                The quality of the photo is good, but I can not see the name of U26.
                Could you post it?
                Is there a motherboard code number?
                • Monument
                  • May 2011
                  • 40
                  • Estonia
                  One end of the resistor should be in contact with the transistor. I believe the motherboard code is dagc3amb8 and I read
                  "KXTC8
                  20020
                  1511"
                  on U26 chip.
                  • Francisco.s
                    • 686
                    • Spain
                    I think this is the code, but I haven't this diagram.
                    See if this diagram helps.
                    • Monument
                      • May 2011
                      • 40
                      • Estonia
                      I think the resistor is R349 with a value of 1Mega ohms.
                      • lezsimply
                        The Wanderer
                        • 657
                        • Philippines
                        yes it is
                        • khaahk
                          • Dec 2013
                          • 814
                          • Estonia
                          Schematics can be found via google. Still, replacing the resistor should not make the keyboard work. The keyboard itself might be damaged.
                          • Monument
                            • May 2011
                            • 40
                            • Estonia
                            Yes, it didn't fix the keyboard, however, the laptop seems to work just fine, external keyboard is also working fine so I assume the keyboard is malfunctional.
                            • shahnld
                              Lenovo legion 5 pro startup issue
                              by shahnld
                              Good day Experts
                              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                              08-24-2025, 12:31 PM
                            • db80
                              Lenovo Ideapad 5 15ARE05 startup issue
                              by db80
                              Hello friends,
                              I've been racking my brain over the past few months on the following issue:
                              I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                              If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                              Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                              I tried all the common alleged „fixes“...
                              07-06-2024, 05:58 PM
                            • coasterghost
                              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                              by coasterghost
                              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                              System Hardware:
                              Processor: AMD Ryzen 7 PRO 5850U
                              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                              09-08-2025, 10:46 PM
                            • totof
                              Lenovo Ideapad 3 15ALC6 motherboard issue
                              by totof
                              I have a Lenovo Ideapad 3-15ALC6 computer that I'm trying to repair.
                              Initially, the computer wouldn't start, and there was no power consumption from the charger. The board itself is reference HS261&HS561&HS761 NM-D521 rev 3.0, where you can find the schematic and board view here: https://www.badcaps.net/forum/troubl...-hs761-nm-d521
                              When I opened it, I noticed three burnt components near...
                              10-26-2025, 10:27 AM
                            • code share
                              Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                              by code share
                              I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                              Here's what I've tried so far:
                              • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                              • Booted successfully on AC power only with the battery disconnected
                              • Visual inspection of the battery — no swelling, burn marks, or connector damage
                              • Battery
                              04-21-2025, 12:50 PM
