case asus eee pc 1015PW
    hai ... I have a case asus eee pc 1015PW. case, do not want to be on. it's about where the problem? I've done replace embedded controller (ec), flash bios. but still the same. 3/5valways voltage there. Thank you so much.
    Re: case asus eee pc 1015PW
    Dİd you flashed BIOS ?
      yes i have flash the bios, but still do not want to be on.
        did u tried to resolder qfn type IC s ?
          check signals ACIN, LIDSW on EC.
            Spidey, what does lid switch do in circuit. I know that it makes the laptop go to sleep mode when switched on but fully understand the signals it gives to which chip? What are the responsible parts?
              but do not use the battery when the laptop bios, straight on and can also be turned off. if the bios battery in pairs again, he does not want to be on. it's about which master?
                I have not replace the power ic, may be power ic.
                  reflow the cpu, but do it properly.
                    ok thank you. i'll try...
                      solved.......thank you
                      http://www.youtube.com/watch?v=FcKDrgZhwLQ
                        good job bowor..
                          can u upload bios file for this model
                            hye bowor what standby current in Amp before you reflow cpu. i see u use adjustable power supply can read the current come in?
                              my one have power but no display i need bios file
