This might help someone else. I bought a "pulled apart" HP G6 that would not display - just a black screen. Power lights come on and the cap light blinks 3 times (indicating ram, I think). However ram is ok. During my tests I checked to see if the cable in the screen was seated correctly and my fingers got hot when I touched the webcam connection to its PCB. I disconnected the webcam and now the laptop boots fine with full display.
					Solved-HP Pavilion G6 black screen
			by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
 YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
 I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
 On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
 I also changed the screen because the PC fell and the screen was broken.
 I changed the battery with a new and original battery.
 I also had corrosion/oxidation on the...
			by howardc64Problem
 This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
			by VcemPzdHello everyone !
 My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor... I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
			by iZakreHello everybody!
 To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
 The thing is that I had installed TeamViewer and could log into the computer...
- Loading...
