acer aspire 6930z power problem
    hi all
    a have aspire 6930z mb: DA0ZK2MB6G0 rev:g
    and it will not turn on neither battery nor DC... when connected blue charging light come on, all voltages seems present but when power button is pressed nothing happens except blue charging light come off... no fans spinning, no nothing... i have to disconnect and wait 10-15 sec and reconnect dc and blue charging light came back on...
    no visible damage, and mosfets seem to be ok, diodes and usual stuff checked...
    i have stripped down everything including cpu and ram and symptoms remain the same...
    any help o guidance will be much appreciated
    Im Back... sort of...
    Re: acer aspire 6930z power problem
    flash the bios first.
      As spidey says try the bios first, also check peak current consumption from 19v. rail. (could be a secondary power supply drains too much power)
        have you tried removing cmos battery and replace with new one?
          if its amd try to replace the rtc battery.. if its still no go, flash or change the bios chip.
          you can check also the clock generator..
            thank you for your replays
            its an intel cpu...
            yesterday i was struggling with my old willem eprom programmer pcb 3.b wich gives me hard time programming spi eproms larger than 1mb (fin future i will mod it to pcb ver 4.5) but i have managed to do so... only one bios at Acer support site, flashed, soldered eprom and now symptoms changed... would not turn at all, no reaction on power button... found some older version an acer ftp site, so i will program it again today...
            i will report my progress...
              i have flashed this bios
              ftp://ftp.support.acer-euro.com/note...30/vista/Bios/
              and now charging light is on, power button has no reaction at all...
              i also tried
              http://global-download.acer.com/GDFi...CER&SC=EMEA_27
              and same thing...
              flash done correctly (unsloder, erase, check blank > ok, write, verify > ok, resolder to motherboard)
              any ideas...
                check EC and south crystalls, if they are good, check for lid and acin signals coming to EC. Also check power button 3.3v and while pressing goes down to 0v. if all ok, then change EC.
