Acer Aspire 5750-Dead, No Power or Lights
  • kev4eva
    • Mar 2012
    • 37
    • jamaica
    Folks am stuck here, really need your help. Got a VIN/ Power in problem
    *Got 19 volts at dc jack connect PJP1 and PL1....page 46
    *PQ6- got 18.5 volts on input and output........page 47
    *PQ7- only 18.5 volts on pins 1-4,........ 0 volts on output
    think i have a problem here, am stuck,
    From here on all other components are 0 volts
    PR14, PL22 PUL- measure 0 volts..................
    missing 5v reg and 3 vreg as current seems to stop at PQ7 ??
    Did i miss a cap or resistor possible faulty that you can point in schematic. Would appreciate any help....am beginner
    schematic: Acer Aspire 5750 schematic
    Motherboard Image
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Acer Aspire 5750-Dead, No Power or Lights
    Voltages at pin 1,2, 3, 23, 24?
    • kev4eva
      • Mar 2012
      • 37
      • jamaica
      PU2- 5v and 3v regulator
      0 volts on all those pins.....input an output....so i think the voltage is cut off somewhere before here whether at the second fet PQ7 ?
      PQ7 -18.5 volts pins 1-4 then 0 volts on the others pins
      • popeye
        • May 2011
        • 155
        Have you removed and checked PQ7 this is a p channel mosfet the gate needs to be more negative than the sorce to turn on the voltage for the battery if you have the battery in you need to check PU1 pin 24 DC inyou should have supply voltage Vin you should have you should have voltage (high) on pin 3 EN
        this switches on the ic that controls the alws3v & alws5v regulators at U2
        • kev4eva
          • Mar 2012
          • 37
          • jamaica
          havent removed PQ7 as yet, i tried with battery in at PU1 pin 24 is 0.2volts and pins3 en is 0.3 volts
          PU2 doesnt switch on as no voltages there, i will remove PQ7 shortly and update you
          • kev4eva
            • Mar 2012
            • 37
            • jamaica
            PQ7 seems fauly so i just replaced it...now
            Pins 1-4 =18.5 volts
            Pins 5-8= 0.4 volts...... was 0 volts before, hmmm seems something draining current here..so turns out PQ7 not the issue??
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              Sorry, im talking about PU1.
              Check the voltage at the cathode of the zener diode on pin 1 of PD5. VIN has 18.5V, so probably the PD5 or PR22 could be open.
              • kev4eva
                • Mar 2012
                • 37
                • jamaica
                thanks, suprisingly PD5 = 18.5 volts
                trying to locate PR22....i see a resistor i think cud be it but got no labels will try magnify the area an locate it
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  If PD5 has 18.5V, and you dont have a voltage on pin 24 of U1, then PR22 could be open. PR22 is connected to one end of PD5. It should read 20 ohms according to your schematic diagram.
                  • kev4eva
                    • Mar 2012
                    • 37
                    • jamaica
                    thanks i really glad your helping me so far
                    found pr22 its connected to positive pin of PD5, its closest to it but unlabelled on pcb
                    PR22= reads 18.5 volts on the one end and o volts on the other
                    sorry for my noob question but...whats the best range to set my meter on to measure PR22 resistance..2000 ohms??
                    • kev4eva
                      • Mar 2012
                      • 37
                      • jamaica
                      that should be PR22....has a light surface abrasin
                      PR22= pin 1=18.5v
                      pin2= 0v
                      • whaldsz
                        • Apr 2013
                        • 395
                        • Philippines
                        PR22= pin 1=18.5v
                        pin2= 0v
                        PR22 should read 10 ohms. Your measurement indicates it's open. Replace it.
                        • Francisco.s
                          • 686
                          • Spain
                          If PR22 is open, then there are many possibilities that PU1 be in shot-cicuit.
                          • kev4eva
                            • Mar 2012
                            • 37
                            • jamaica
                            will do that an post in the next few hours.....any 10 ohm black smd resistor will do with value of 100??
                            • kev4eva
                              • Mar 2012
                              • 37
                              • jamaica
                              i replaced PR22...it reads 10ohms, when i give power now it doesnt turn on an after reads 1.5 ohms
                              now: any 10 ohm resistor i replace at PR22 its destroyed
                              • kev4eva
                                • Mar 2012
                                • 37
                                • jamaica
                                cud PU1 IC be faulty?-i notice dc in pin24 is shorting to ground
                                • whaldsz
                                  • Apr 2013
                                  • 395
                                  • Philippines
                                  Yes, remove PU1 and test pin 24 to ground to confirm.
                                  • spidey
                                    climbs
                                    • Dec 2012
                                    • 644
                                    • Cyprus
                                    i didnt read whole posts, but with the given information i can say that it is protection error. That means you have a short somewhere or somehow protection circuit is in error state.
                                    i would short PQ7 pins 1 and 8, limit power supply to 3v and limit current to 200ma and connect to board. search for heat, and slowly raise voltage and current limit. it is most probably a bad cap or problem in your stand by circuit.
                                    if you dont be careful you can damage your board.
                                    • kev4eva
                                      • Mar 2012
                                      • 37
                                      • jamaica
                                      i wish i could do that my friend however havent purchased a dc power supply as yet am just a beginner, i appreciate your advice alot i will try retrace that circuit and also check charger IC
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        There is a very high probability that PU1 is shorted as francisco said and the result you got in post #15.
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
