Advent laptop - screen issue?
  • spleenharvester
    • Mar 2010
    • 921
    Somebody on another forum I'm on has this odd issue with unknown model Advent laptop, thought I'd crosspost it here.
    http://www.youtube.com/watch?v=g9B-RjbNY9s
    Apparently it's fine on external monitor. But it has that odd green discolouration and then goes back to normal which makes me wonder if there's a GPU problem there.
    Unsure if it's LED or CCFL.
    Any ideas?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Re: Advent laptop - screen issue?
    Update, it's a CCFL screen, laptop is an Advent 5712, apparently doesn't go back to normal after login. I've told him he's probably best trying to replace the inverter first (I've seen similar before and they cost £3 each so it's a good place to start)
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      That's got nothing to do with the inverter. I'd suspect loose/dirty LVDS cable first, cracked LCD second, bad GPU third. I strongly believe it's the screen tho.
      Now don't go and tell me the screen isn't visibly cracked - i've seen my share of bad LCDs with weird behaviors, and looking really really carefully, every time there was a hair-thin crack somewhere on the top side, where the chips-on-glass are.
      A working TV? How boring!
      • JJR
        • Mar 2013
        • 171
        Agree with Th3 its probably a faulty screen / cable. First thing to do is remove the screen bezel and jiggle the cable, if the screen changes you've found your problem. Then try another screen, I try to have an old ccfl screen handy for testing.
        • dj_ricoh
          • 2073
          did you try to run it in extern monitor?
          if yes and the same we all know what you have to do "REFLOW/REBALL"
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            In the first post he mentioned that external is OK.
            • VcemPzd
              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
              by VcemPzd
              Hello everyone !
              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
              04-28-2025, 10:14 AM
            • jean luc ferre
              laptop hp g72 b52sf screen problems
              by jean luc ferre
              on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
              the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
              i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
              i don't understand the reasons of the white stripe at the bottom of the screen below the task...
              06-07-2025, 03:27 PM
            • Mirenia
              Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
              by Mirenia
              got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
              The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
              If this happened once, then the laptop only runs for a few minutes until restart.
              This happens regardless while staying in windows or uefi or in a linux environment.
              At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
              01-05-2025, 05:15 PM
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • ahmarzo
              Acer laptop battery draining issue
              by ahmarzo
              Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
              Help me to diagnose this issue as there is no shortage in the inputs MOSFET
              08-02-2025, 06:39 AM
