DC Socket Suppiers in UK
  • JJR
    • Mar 2013
    • 171
    Hi All
    I'm struggling to find a decent supplier of laptop dc sockets in the uk, I am sick of ebay rubbish were the tabs are not deep enough for motherboards.
    Can anyone suggest a good supplier please?
    Cheers
    DAve
  • spleenharvester
    • Mar 2010
    • 903
    Re: DC Socket Suppiers in UK
    +1 to this, I ordered a Dell jack the other month that broke in two weeks, and every IBM X31 jack I ordered was too tall for the plastics.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • JJR
      • Mar 2013
      • 171
      I see Roltas website is now notebookbits.co.uk anyone used them?
      • Isabella91
        Possible to convert eMMC Socket to a micro SD Card socket?
        by Isabella91
        I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
        Read/Write a Micro SD Card from an eMMC Socket.
        I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
        Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
        Not to remove...
        01-14-2024, 05:10 PM
      • warsztat
        Acer AN515-57-577G JDIMM1 socket not working.
        by warsztat
        Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
        11-18-2024, 09:13 AM
      • AJ847.63e
        LGA 1700 Socket Replacement Tips & Tricks
        by AJ847.63e
        Hi All,
        Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
        I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
        07-24-2025, 06:57 PM
      • dicky96
        Need to buy buck regulator MP2329CGG but struggling to find supplier
        by dicky96
        Hi guys
        I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
        Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
        I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
        Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
        03-05-2021, 08:44 AM
      • Geomih
        CPU socket replacement soldering profile
        by Geomih
        Hi All - I am hoping someone can help with some pointers (complete noob here!)
        I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
        My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
        The simple stuff like a small memory module isn't a big deal because there are
        12-11-2023, 11:07 AM
