Acer Aspire 4745g power problem
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Acer Aspire 4745g power problem
    check rsmrst at sio after pressing power button. 3 volts should come
    • lezsimply
      The Wanderer
      • 646
      • Philippines
      Good day. I have ask the owner again what he was doing when the laptop crashed. He told me that he was playing candy crush when suddenly the laptop froze. He pushed the power button forcing it to shutdown and after that it never opened again.
      When I took the laptop apart I noticed that the ventilation area, the one on the heatsink is clogged with dust. At least 3mm thick of black cottonlike sponge. Visually hot air produced by the heatsink cannot go through it making the gpu very hot. So is it possible that gpu is the cause? considering that the voltages are ok.
      And other thing I tried to turn the laptop on without the processor and memory same thing happens power led blinks once then nothing.
      I really wanted to make sure that we took every step to ensure that power is ok on the motherboard before doing a reflow. It is the last option that I'm considering.
      As of now I'm inspecting the gpu and there are memory chips around it, maybe I need to reflow those too, just in case. Thank you very much for your help and patience.
      • dj_ricoh
        • 2073
        worst case you need to reball.
        but hey what could it get more bad that the notebook doing nothing
        reflow and tell us what happen
        • lezsimply
          The Wanderer
          • 646
          • Philippines
          I managed to locate rsmrst on u16 pin no 75. pushed power button jumps from 1.47v to 0v. Is this bad? thanks very much.
          @dj I'm preparing my station for the reflowing
          • jtamad44
            • Apr 2013
            • 145
            • israel
            change the gpu chip with new one, i'll be ok..
            • dj_ricoh
              • 2073
              #26
              so what happen?
              • lezsimply
                The Wanderer
                • 646
                • Philippines
                #27
                sorry for the late reply, been busy for awhile. I tried doing a soft reflow on the gpu and yet still same issue, today I'll be reflowing the video memory chip that I found beside the gpu chip. If nothing happens I think this board is junk.
                Is it ok to reflow the SIO chip? thanks again!
                • jtamad44
                  • Apr 2013
                  • 145
                  • israel
                  #28
                  if you can reball the gpu, reball it, is not junk yet.. you need patient and time.
                  • lezsimply
                    The Wanderer
                    • 646
                    • Philippines
                    #29
                    Thats the problem, as of now I do not have the equipment to perform reballing procedure.
                    I tried to reflow the SIO chip, whenever I press power button power led no longer blinks but still no power. One thing I also notice is that whenever I plugged the ac adapter amber light lit on LED2 I think its the battery indicator. There is no battery inserted and the motherboad has been taken out from the case. Why is it doing that? strange...
                    • lezsimply
                      The Wanderer
                      • 646
                      • Philippines
                      #30
                      I think it may have gotten worse. Laptop is totally dead with no lights. no response from power button when pressed. But Still 5v and 3.3v are ok. Do you guys from Phil know a place where I could buy npce781La0dx SIO chip or do I need to order it from ebay? Thanks again
                      • lezsimply
                        The Wanderer
                        • 646
                        • Philippines
                        #31
                        For the record I would like to say thanks to all people involved in my post. The issue is now solved. What I did was, I replaced two smd capacitor underneath the processor socket. This is quite similar to those toshiba nec tokin problems. Never knew that the problem lies just underneath... Again thanks to all and kudos to badcaps!
                        • nuclearfuhrer
                          • Apr 2014
                          • Philippines
                          #32
                          sir, lezsimply..
                          can you please specify what value of smd capacitor you replace on the motherboard? i think i have the same problem on my laptop.. like to replace it but hav no idea what capacitor is.. thanks in advace sir..
                          • dj_ricoh
                            • 2073
                            #33
                            tantalum or smd?
                            • lezsimply
                              The Wanderer
                              • 646
                              • Philippines
                              #34
                              As I can recall its labeled 330 d. its a 2v 330uf tantalum capacitor. I replaced 3 of them. just under the processor. I had 2 shorted but I replaced all 3.
                              • dj_ricoh
                                • 2073
                                #35
                                awesome work.
                                when i have board like that and i have some time i lift up the caps and check them.
                                good to know i`m doing the right thing
                                • rickybucalan
                                  • May 2013
                                  • 322
                                  • philippines
                                  #36
                                  hi to all i just wanna ask if you know how to reset the bios of this laptop acer 4745g.
                                  tnx..
                                  • AltraqComputer
                                    • Sep 2015
                                    • 10
                                    • philippines
                                    #37
                                    good day, got same issue here, is this resolved or not, can pls... help me regarding this ive done the check v all of the instruction except the reflow. what possible parts causing the the problem specific parts..... thanks
                                    • sasser
                                      • Dec 2012
                                      • 364
                                      • Malaysia
                                      #38
                                      same issue. what value u read the cap under processor ?i got to gnd is 054 on positif side. its ok?
                                        ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-12-2024, 03:28 PM
                                        ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                        This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                        This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                        09-06-2024, 05:27 AM
                                      • DenK
                                        Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                        by DenK
                                        Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                        1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                        12-06-2024, 01:29 AM
                                      • Bonaventure Vigil
                                        ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                        by Bonaventure Vigil
                                        Dear All,
                                        Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                        At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                        12-12-2024, 10:22 AM
