Acer Aspire 4745g power problem
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day to everyone. I've got an acer aspire 4745g laptop which turns on then off again in just under 1 sec. When I press the power button the power led blink once then off and there is no sign of life. I need to unplug the power adapter to make the power led light again. I've tested the adapter and its ok. Power jack and its wire are ok because voltage are present on the motherboard.
    Motherboard receives 19.5v. Are there any areas I need to check regarding power. I also checked the motherboard for burnt components and I see none. I also got the schematic diagram for its board. Hope someone helps. thanks!
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Acer Aspire 4745g power problem
    check for 5v 3.3v alw
    saw the schematic, check PL15 5V, PL16 3V
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      thanks for the reply. checked 5v on RT8206B pin no.14 (en1) OK and 3.3v on pin no.27 (en2) OK. 5v on PL15 is 5.14v and 3v on PL16 is 3.29v. Is this ok? I also measured sw1 3.3v when pressed becomes 0.5v.
      • dj_ricoh
        • 2073
        check pq63,64,65 and 66
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          thanks again. pq63 and pq64 5.18v is present, pq 65 and pq66 3.38v is also present. where else do I need to check?
          • whaldsz
            • Apr 2013
            • 395
            • Philippines
            Voltage on PL11, PL12, PL9, PL17, PL14, PL7, PL13?
            • dj_ricoh
              • 2073
              check V on U40 ( W25Q32BVSSIG )
              • lezsimply
                The Wanderer
                • 645
                • Philippines
                good day, @ whaldsz all the components you have mention pl7 ,pl9, pl11 ,pl12, pl13, pl14 and pl17 have 0v reading. Is that bad? thanks
                @ dj 0v on pin no 8 on u40. thanks
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  Then check the resistance to ground of those coils and mosfets too.
                  • dj_ricoh
                    • 2073
                    pin 8 on U40 its VDD and it shows +3V .
                    did you check with power on or off?
                    do you have tools to remove it? atleast a soldering iron.
                    • lezsimply
                      The Wanderer
                      • 645
                      • Philippines
                      ok sir whaldsz Im on it.
                      @ sir dj, I dont have the chance to measure u40 with power because it won't turn on. Yes I do have the tools to remove it. Is u40 the bios chip?
                      thanks again to both of you!
                      • dj_ricoh
                        • 2073
                        Yes thats bios chip. remove it and see if power its restore.
                        without bios it will not Power up but you can see if power led its stable and the battery its charging.
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          @dj or you mean U29 (SPI Flash)? pin 8 of U40 comes from +3V (controlled by MAIND) and would not turn on unless power button is pressed.
                          • dj_ricoh
                            • 2073
                            go on page 44 and try to find some V like the P channel fets and that isl.
                            can you reflow the board? did you try?
                            • lezsimply
                              The Wanderer
                              • 645
                              • Philippines
                              @whaldsz, the resistance to ground of all mentioned components are ok, low resistance. u29 pin no.8 has 3.38v reading
                              @ dj, haven't done any reflows on the board but I do have a hotair station just incase.
                              I've been reading a lot of forums regarding this laptop and the usual problem involves the gpu. I hope that is not case. thanks again.
                              • dj_ricoh
                                • 2073
                                you need to reflow but make a bottom heater to not just from top.
                                or you can do from top ( a light reflow) just to see if anything change.
                                • lezsimply
                                  The Wanderer
                                  • 645
                                  • Philippines
                                  Before I reflow anything, I'll be redoing every test on all components just to make sure that I haven't overlooked any readings.
                                  This is what I got on u29 pins (ISL88731A)
                                  pin 11 (vddsmb) = 3.3v
                                  pin 26 (vcc) = 5.18v
                                  pin 22 (dcin) =18.87v
                                  pin 02 (acin) = 4.02v
                                  are these voltages relevant to my problem? Thanks again!
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    What is the lowest resistance did you measure?
                                    • lezsimply
                                      The Wanderer
                                      • 645
                                      • Philippines
                                      13.9ohm on PL7 why?
                                      • whaldsz
                                        • Apr 2013
                                        • 395
                                        • Philippines
                                        i think not. you mentioned in your post #4 that you already have 3.3V and 5V.
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
