Compaq nc6000 power problem
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Hi, forum I have a compaq nc6000 which is having a power problem, The mosfets around the D1008 just gets shorted when Ac adapter is plugged in, I have replace this mosfet several times but the same problem occurs immediately you plug in the adapter, I need help solving this problem,
    The mosfets are shown in the picture attached
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Compaq nc6000 power problem
    I managed to solve this problem, the laptop now works perfect. thank you alll
    • dj_ricoh
      • 2073
      What did you do just swap that mosfet?
      • crash-cyberdrive
        • Jun 2013
        • 62
        • US
        A bit of info on what was done to fix the problem would be nice to all members of the forum.
        A Picture of subject is always Welcome
        Things saved from the e-landfill:
        Vizio VA26LHDTV10T 26" - Bad EEPROM Cap
        Asus PTGD1-LA Full Recap - Cha1 DDR socket damage
        MSI PM8M3-V Unstable CPU Recap CPU VRM circuit
        ViewSonic VA712B - still working on it
        Kindle Fire USB Connector
        MSI G31M-F Full Recap - Record Breaker done in 3Hrs.
        MSI P67A-G43 BIOS chip Reprogram - Tested and Happy
        The list will go on thanks to the people of this forum and many hours of reading.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Duranitron
          Asus x512dk rev 2.1 power on problem
          by Duranitron
          When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
          Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
          11-26-2024, 10:22 PM
        • EazyBone
          LG OLED55C9PUA power problem
          by EazyBone
          Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
          Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
          I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
          The power supply to t con is different story.
          This...
          06-23-2023, 07:43 AM
        • Dr.d
          Help please..Lenovo ideapad 5 14itl05 power and charging problem
          by Dr.d
          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
          04-05-2024, 11:48 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
