Laptop / battery / charger voltages?
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Hi there. I have some semi-functional li-ion laptop batteries laying around, i have opened all of them, now i have 3 packs that have some life in them. I want to use them for different projects around the house.
    I have started a thread before on this forum about IC to charge at 12,6V (11.1 or 10,8v nominal) but it is problematic to charge them purely in series as a single unit due to possible disbalances. Therefore I will try to use controllers that are inside the battery.
    I have managed to get 2 of them to charge (1 just directly connecting to positive and negative terminals, another with a small clicky switch to get a required impulse to start charging). I am still working on the last one to charge.
    The question is, if the cells are connected in 2p3s system, the charge voltage would be 12.6V to charge both 10.8V and 11.1V packs, provided that i charge the cells directly. But how much of voltage do i have to supply to the controller so it controls the whole charging process? Knowing that most power bricks are 18-20V there has to be a dc-dc converter for charging a battery somewhere. Is it inside the laptop or the battery itself?
    Long story short, do i have to supply those 18~20~whatever-high-volts to the pins of the battery controller and it regulates the voltage itself, or i have to give it much lower voltage (close to 12.6V i assume) not to cook the cells.
    And does the battery controller itself regulate the charging process, for CC, CV, balance stages? Or it is the laptop doing it over the data/clock pins?
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Laptop / battery / charger voltages?
    Could you show some diagram how you did it?
    If you are charging the two batteries, can your charger deliver the needed current to fully charge the battery? If so, how do you control when to disable the charger? Usually in laptop, the charger ic inside the laptop is controlling it for you and the host system is the one giving the commands when to enable or disable charging.
    If you are going to take a look at some datasheet of the charger ic, there are loads of example circuit in there which will help you implement your own standalone charger which can enable/disable charging of your batteries automatically.
    • domas
      News Hater
      • May 2013
      • 323
      • Denmark
      Well, I think you understood me wrong. I had a simmilar thread in another section about charging li-ion batteries in series. https://www.badcaps.net/forum/showthread.php?t=28910
      I have learned there that you can not charge them as a single unit, you need to monitor each cell individually and discharge it if voltage is too high for one part of it. Therefore i am using a controller inside the battery pack to do that for me. Well it is more of finding out what does that controller do, and if it is enough? Because I am aware about the ic inside the laptop, and i am not sure if I can do the whole smart charge without laptop part. I haven't charged them fully yet, i have just tested if they can be charged over the controller, as some controllers require some code to do so. I haven't charged the packs fully because as already mentioned i am not sure if the controller itself will stop the current flow to the cells.
      For example see this: http://www.allpinouts.org/index.php/...0_D600_battery
      I have similar pinouts on one of my pack. 1+2 pins is where i connect the positive cable of P/S, and 8 + 9 is the negative. One of the packs needs a trigger (clicky button over 100ohm resistor) from 1+2 pins to pin #5 to start flowing the current to the pack.
      Another has only 6 pins IIRC and i just used 2 of them, 1st and the last to supply current for the controller and it starts charging the cells without any trigger.
      Yes I have more than powerfull (well, for this application) power supplies.
      Does anyone know if the controller inside the battery pack is anyhow usefull in my case?
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        As far as I know, most laptop battery packs charging are designed to be controlled by the host (laptop). But I could be wrong.
        Take a look at the attached pdf for example - Battery Circuit Architecture (Texas Instruments). The circuit inside the battery pack are comprised only of circuit protection and battery monitor (temp, etc.).
        Other than that, I guess, the control that you require cannot be provided by the built-in controller. But again, I could be wrong.
        • Thomasraud
          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
          by Thomasraud
          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
          QUOTED
          -It works on charger (without battery connected-only charger)
          -It works on battery (without charger connected-only battery)
          -& it also works when plugged in battery & charger, but it's not charging the battery
          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
          and..
          QUOTE
          The IC cannot maintain the input current level
          06-28-2022, 06:47 PM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
        • Klevjetack
          Charge a L19D3PDA battery externally from the laptop
          by Klevjetack
          Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
          03-05-2024, 07:26 AM
        • YellowJacket
          Battery charger - STIHL AL 300
          by YellowJacket
          Hi friends,
          I got to fix STIHL AL 300 battery charger, for mower machines, which works fine only when the battery is discharged ( haven't tried it already, since I got only fully charged battery, but that's why I have been told ). When the battery has some % of voltage, the charger doesn't work. In this case, the red LED starts to flash 10 times, and there is no voltage at the output. The customer tried more batteries, and it worked like this with all tried batteries ( so looks like not a battery related issue ).
          I would try to discharge the battery ( with few 12V...
          08-02-2023, 06:18 AM
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
