Heat guns near BGA packages
  • spleenharvester
    • Mar 2010
    • 903
    Basically I need to replace a QFN chip, and given the solder joints are underneath, I need to use a heatgun.
    The chip is about 7cm away from the Northbridge chip - an Intel HM55 so not really so much prone to failing.
    1) Is this likely to comprimise the structure of the BGA package if there is nothing wrong already?
    2) Should I have the heatgun directly over the BGA package once I'm done soldering the QFN chip to make sure the BGA joints are all uniform?
    I see the term "light reflow" being thrown around a lot as a method of checking if a BGA is at fault, but this seems like a very shotgun approach to me, hence the above questions.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Heat guns near BGA packages
    you can use kapton/aluminum tape to cover the bga chip.
    • thesloc
      Banned
      • Dec 2011
      • 587
      7cm is pretty far.
      As long as you don't move the board while applying heat that much, the bridge will be fine...
      use good flux tho, like amtec to smooth the process.
      • spleenharvester
        • Mar 2010
        • 903
        I'm still using that horrid cheap yellow gooey flux lol. Need to bin it already, it's crap.
        Cheers!
        • tomodachi
          • Apr 2012
          • 602
          • Turkey
          Cheers
          7 cm is very safe distance for heatgun replacement, but if you hesitate you can use aluminium foil to protect the hm55 or others which you dont want to fry.
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • harp
            detecting heat with IR LED receiver
            by harp
            I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
            So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
            Something like termal camera, but in one spot, any simple circuit?...
            09-06-2023, 06:03 PM
          • ludovik
            Moto G84 short after heat
            by ludovik
            i was reballing the power manger of a moto g84, after applying heat i tried to power on and it wouldn’t.
            i injected 1.5v to some capacitor that seem in short because both side beep if tested.
            when i inject i feel the cpu burning;
            since the cpu is exactly on the other side of the board, is that possible that the heat from the reballing damaged the cpu? do you know where i can find schematics or what can i do?
            i know this is not enough to explain the situation so if you need any other info ask me please!
            Thank you very much in advance
            11-08-2024, 02:13 PM
          • jm1234
            Solder joints on heat sinks matter?
            by jm1234
            solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
            I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
            04-28-2024, 04:38 AM
          • myth77
            direct heat stencil,where do you get it? and how to prevent warping?
            by myth77
            So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
            1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
            2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
            01-17-2022, 05:06 AM
