Toshiba Satellite LED screen no backlight
  • mangkook
    • Jul 2013
    • 13
    • Malaysia
    Hi guys
    I have a problem with Toshiba Satellite L500 led / lcd no backlight problem
    the chronology is like this:
    1. Toshiba Satellite L500, busted LCD, Still have backlight. Only parts of it cracked.
    2. Order LCD screen from online, part no: LP156WH1
    3. problem with stock lead to replacement with compatible LED screen part no: LP156WH4
    4. assembled the LED screen (no inverter obviously) > boot, blank no backlight. image is visible but very faint
    5. tested with old LCD + original inverter > boot, also blank no backlight (wierd, used to be OK). image is visible but very faint.
    6. tested the vga to external monitor, OK.
    Now I've searched the internet and found suggestions that maybe the fuse controlling the power is busted.
    Is there anyone with the same experience? please help
    1. can it be that the fuse that control the power is busted?
    2. Can I fix it?
    3. if answer to both question 1&2 is YES, where can I locate this fuse and how to fix it.
    if I should post some attachment pic, which part should I capture?
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Toshiba Satellite LED screen no backlight
    The fuse looks like a surface mount resistor, sometimes white or green or black coloured I think and usually marked with a single letter like a "P" to indicate the current rating.
    It will feed the 19v adapter supply to a number of adjacent pins on the mainboard connector tied together.
    Sometimes when a wrong LVDS cable is used, the control lines to the backlight circuit can be damaged. These control lines usually come from the keyboard controller IC.
    • mangkook
      • Jul 2013
      • 13
      • Malaysia
      thanks for the quick reply
      so I should find this fuse on the motherboard? I already took out the motherboard and still trying to find it using magnifier.
      • rievax_60
        • May 2012
        • 897
        • australia
        Thats right. Often when I dont have a schematic, I look for pins on the mainboard LVDS connector that are tied together and try to trace where the track goes to. When pins are tied together, it is because they are for power rails or ground connections.
        • mangkook
          • Jul 2013
          • 13
          • Malaysia
          I wonder if the schematic : https://www.badcaps.net/forum/attach...7&d=1373766252 , from older thread: https://www.badcaps.net/forum/showthread.php?t=30076
          can be any use?
          I'll try to take pic tomorrow. its already too late here in my country and I dont have any camera with me apart from my old phone camera.
          update with phone camera, focus on JLVDS part.
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            find the schematic, check lvds circuit. find Vin(18-19v), on/off(+3v) and brightness(150-200mv to 2-3v). Most probably you dont have vin or on/off signal. trace back this signals and fix the fault.
            • mangkook
              • Jul 2013
              • 13
              • Malaysia
              the schematic found here: https://www.badcaps.net/forum/attach...7&d=1373766252
              are quite similar, its LA-4982P while my board is LA-4981P. perhaps just minor change?
              can I use this as reference? I'm very new in this. dont even understand what exactly I'm looking for.
              I found many VIN in these pdf schematic but can't decide if they're connected to LVDS.
              • alihomee
                • Dec 2012
                • 1575
                • malaysia
                you need to test the voltages on inverter one is 18v and other is 3v to turn on the inverter if not present then chech on lcd connector on mother board
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  they are nearly the same, i have both of them. you can use the schematic.Page 18 of schematic, check for +LCD_INV and, BKOFF#.
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    if C677, C678,C392 are (or one of them is) not short, and L17 is good too then you should get +18-19v on +LCD_INV. So if BKOFF# is not +3v then it is EC problem. Anyway measure them all, and post back.
                    • mangkook
                      • Jul 2013
                      • 13
                      • Malaysia
                      thanks guys
                      I'm waiting fro my brother who's into electronics to come, for the meantime I'll try to crunch some of the info above and going to find multimeter and learn how to use them
                      I'll be back.
                      already spend 100 buck for the LED screen and I'm not going to let this thing die on me!
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        dont worry, its just a back light. if cant fix the problem, anyway we can make it work.
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          Same issue happened to me with my customer's Dell Inspiron M5030. Hope that shine some lights.
                          Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            for that one, you must open a new thread, with your measurements. Dell m5030 has a known issue, blown fuse near lcd con. on motherboard. check it.
                            • mangkook
                              • Jul 2013
                              • 13
                              • Malaysia
                              Ok guys, under my brother guidance,
                              I can confirm using multimeter that C677, C678,C392 are NOT short
                              I hope I read it right..
                              photo sharing sites
                              • spleenharvester
                                • Mar 2010
                                • 902
                                Probably isn't this but look top-down into the LVDS connector. Are all the pins straight?
                                I had this on an L300, and it turned out that because I plugged the connector in at a slight angle, two pins had bent and ended up in the same part of the connector.
                                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                • spidey
                                  climbs
                                  • Dec 2012
                                  • 644
                                  • Cyprus
                                  would be nice to see inverter side connector, with pin measurments.
                                  • mangkook
                                    • Jul 2013
                                    • 13
                                    • Malaysia
                                    I hope the pic is suffice..
                                    screen shot on a pc
                                    I edit the pic to overlap to show the connector side according to the LVDS socket
                                    also, Ive checked the connector, all of it and cant find anything bend or something wierd.
                                    I post a few pic just to show you guys my current situation
                                    photo storage
                                    • spidey
                                      climbs
                                      • Dec 2012
                                      • 644
                                      • Cyprus
                                      ok, you dont have an inverter. it is a led converter. so the problem is wrong connection. just make sure pins located correctly by chaecking led panels circuit schematic. it should work when you find and change.
                                      • spleenharvester
                                        • Mar 2010
                                        • 902
                                        OP did you get round to taking some DMM measurements on that connector? That all the voltages are there etc?
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • FallenOne008
                                          Asus G712L No Screen Backlight
                                          by FallenOne008
                                          Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                          The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                          03-31-2025, 08:27 PM
                                          Toshiba Satellite Pro L300-156 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro L300-156 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L300-156 boardview and L300-156 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A50-E-1CH Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A50-E-1CH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-E-1CH boardview and A50-E-1CH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 07:07 AM
