Dell Inspiron: M5030 No Backlight LED
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Hi all.
    Im repairing this dell m5030 but it has no backlight on the lcd. Things to note:
    • Screen is working
    • Cable is ok
    • Tried other working led screen and same issue.
    Anyone has experienced this issue before? Any links to schematic manual?
    Thanks!
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Dell Inspiron: M5030 No Backlight LED
    how do you know the cable is ok? did you take a MM and check every lane? Other than that i'm thinking motherboard
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      Tried another working cable and same issue. So MM is the culprit.
      • DJduck
        • Dec 2012
        • 229
        • Estonia
        Motherboard's LCD led controller is toasted, see if you get any voltage on the pins.
        I can put text here?!
        • speedypro
          • Feb 2013
          • 561
          • United Kingdom
          Thanks but what pins?
          • speedypro
            • Feb 2013
            • 561
            • United Kingdom
            I'll answer this thread: I have used a little of MEK and wiped around the gpu and all is well. I now have the backlight once again.
            • mangkook
              • Jul 2013
              • 13
              • Malaysia
              so your problem gpu issue? my Toshiba L500 gpu are socketed to PCIE, are yours too? any idea how to clean them? I got a can of CRC Co Contact Cleaner.
              • dj_ricoh
                • 2073
                • uk
                i rly don`t understand what that MEK means. any one helps me with that translate?
                got one that its doing the same.
                gpu related? i need to reflow?
                or missing Volt.
                • speedypro
                  • Feb 2013
                  • 561
                  • United Kingdom
                  or missing Volt.
                  Dude...just google. See wiki
                  Also wipe around the southbridge chip
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    Methal Ethal Ketone. Carcinogen. I've watched 5 people die from brain tumors from using it to clean their hands.
                    sigpicThe Sky Is Falling
                    • dj_ricoh
                      • 2073
                      • uk
                      SPEEDYPRO
                      When you come to London tell me so i can buy you a COFFE
                      reflow did the trick no time wasted on this dell TY SIR
                      • MisterD
                        • Oct 2012
                        • 668
                        I'm working on a Dell M5030 LED with no Backlight for a friend,shined a small flashlight on the screen and could see the images so I removed front plastic bezel around the screen, then removed the two top screws and 4 side screws.
                        unplugged webcam connector and was able to access the circuit board on the back of the screen, applied some light heat from a heat gun directly to the circuit board only and then some cold spray and isolated it down to a smaller area on the board,
                        after reaching just the right temperature I had backlight again. upon close inspection of the circuit board using a magnifying glass I noticed some poor looking solder connections on what looked like 3 resistors that were all 3 in a row.
                        after I re-soldered the connections on them it seems to be working good now, left on for several hours with no failure. left off for 2 hours then turned back on and still had backlight, not sure if it's fixed yet, will leave off overnight and check again in the morning.
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          Ha! Just saw this! Yea cool. But MEK is dangerous, very!
                          • rifat490
                            • Nov 2016
                            • 2
                            this is really interesting.really amazing.thanks for that.
                            • flaworlds
                              • Dec 2016
                              • 2
                              • Vietnam
                              maybe cable not working
                              • computerbacon79
                                Dell Inspiron 3480 All in One corrupt Bios issue
                                by computerbacon79
                                The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                05-06-2025, 06:43 PM
                                DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:36 PM
                                DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                09-12-2024, 03:30 PM
                                09-12-2024, 03:28 PM
                                DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
