Sony MBX-224 fan never stop.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Already flashed bios to new version and checked heatsink glue.
    Any help? Tks
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: Sony MBX-224 fan never stop.
    check EC or thermal IC and around. Schematic is shared in the forum.
    • Francisco.s
      • 686
      • Spain
      Check mosfet Q79, an over-current could be damaged it.
      Also check D31.
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        solved, replaced U4 NPCE783LA0DX
        tks all
        • jaspr
          • Jun 2014
          • 7
          Hello Friends I bought second hand Sony Vaio PCG-41213W yesterday, It worked well doesn't showed any error or activity for 4-5 hours. But today when I turned it on,it doesn't start, after the windows logo, all lights and display turned off, but processor fan continue running, only stops after removing battery. when I turn it on it runs for 30 seconds, first keyboard's light turns to dim and off, then it produces a sound of spark(short) then all lights goes off and fan still running, please suggest me solution,, thanks
          • dj_ricoh
            • 2073
            that`s why they sold it!
            they knew the video chip its bad.
            you need a reball for that chip or swap
            • jaspr
              • Jun 2014
              • 7
              hey thanks dj_ricoh for support, can you please tell me from where I can get that video chip? and is it easy to replace that video chip?? or should I swap the motherboard? please suggest any online web store for both solutions, that can send items worldwide.
              thanks..
              • ghojariya abdul
                • Jul 2014
                • 39
                • india
                in my case fan not working i just change mosfet q79 and its done.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3598
                  • slovakia
                  jaspr> do a reflow and u have it worked for few month/s
                  • mahfooz
                    • Jul 2014
                    • 8
                    • india
                    thanks
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • x_orange90_x
                      Seven Leagues Slot Machine stop button issues
                      by x_orange90_x
                      I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                      The issue now is the Stop buttons are intermittently...
                      02-12-2025, 10:01 AM
                    • Califauna
                      Connecting charger cable causes Sony WH-10000MX2 bluetooth headphones to stop working
                      by Califauna
                      I have a pair of WH-10000MX2 bluetooth headphones with a strange problem. Connecting the charging cable causes the headphones to no longer turn on when pressing the power button.
                      I thought I had 'fixed' this when I took them apart and disconnected the battery for 15 minutes and found as soon as you disconnect the battery they can be powered on and off as normal using the power button. But then the moment you connect a charging or data cable to a charger or laptop USB port, the power button stops working and the can't be turned on again. No response.
                      The...
                      02-28-2024, 06:14 AM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
