Asus Pro61S dont power
  • kaplanerkan
    • May 2013
    • 7
    I have a Laptop and missing 3.8V on mainboard.
    Here is the Informations:
    • Asus Pro61S
    • F50SL Mainboard
    • Rev 2.1
    Anyone got a schematic for this Laptop?`
    thanks
    erkan
  • spidey
    climbs
    • Dec 2012
    • 648
    • Cyprus
    Re: Asus Pro61S dont power
    what is 3.8v for ? i'll check schematic tomorrow at my office.
    • kaplanerkan
      • May 2013
      • 7
      Thank you spidey.
      Tomorrow i can give you more informations about 3.8v and images from mainboard.
      • kaplanerkan
        • May 2013
        • 7
        Hello
        here is an Image and Voltage before i removed the QFN.
        (No power, no Leds and no Fan goes on)
        and here is the Voltage after i removed the QFN
        (Power goes on and green leds to be glimpsed)
        On the QFN i can see following Information:
        • 17015
        • ETP 915 (or 916)
        • ISAM
        I think its a power QFN but i'm not sure.
        It can be a MAX 17015 ?
        I can not say anything without schematics.
        thanks
        erkan
        • spidey
          climbs
          • Dec 2012
          • 648
          • Cyprus
          it is maxim 17015A. it is charging ic.(şeması yok ama bom var. ordan baktım max17015A)
          • kaplanerkan
            • May 2013
            • 7
            I also thought the same thing that this is a Max17015A and this morning i ordered 5 pcs.
            Hopefully i get my order on Wednesday.
            I'll tell you after I've changed this part.
            (cok tesekkürler, lanet kartin hicbir yerde schematic'i yok, parali satilan sitelerde bile yok, bulsam hemen alicam)
            erkan
            • spidey
              climbs
              • Dec 2012
              • 648
              • Cyprus
              asus_f50sl_r1.1_r2.0_r2.1_boardview.zip:
              Your file of 18.63 MB bytes exceeds the forum's limit of 1.91 MB for this filetype.
              Can somebody tell me how to upload it here ?
              • whaldsz
                • Apr 2013
                • 395
                • Philippines
                you could probably upload it to your skydrive or dropbox account or any file hosting site and share the link here.
                • kaplanerkan
                  • May 2013
                  • 7
                  i have changed 2 components: look at the picture and Laptop lives again.
                  Power goes on and charging is ok.
                  Now I have not 3.8V but ~4.8 V
                  @spidey
                  If you have a schematic for this model, I want like to have it.
                  thanks
                  • Francisco.s
                    • 691
                    • Spain
                    Have a look to this schematic.
                    • ryogadan
                      • Apr 2012
                      • 6
                      • Italia
                      i have a similar but more boring problem with this mainboard.
                      The notebook works perfectly with battery but doesn't work when i try to turn on the notebook without battery and with AC only.
                      A couple of informations:
                      - I have tried 3 power pack with the same result
                      - I have tested and found some 19V in several point of the mb
                      - If i turn on the notebook with battery AND AC Power everything works correctly AND the notebook still works if i pull out the battery.
                      Can You help me?
                      • gsmcannt
                        • May 2014
                        • uae
                        asus pro61s ok bios file plz help me may email-gsmcannt@yahoo.com
                        • aleksandar.s
                          • Jun 2017
                          • macedonia
                          Can You help me?
                          did you solve the problem because I have the same problem with asus x61s
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            LM393 Failure???
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • ShadowAi
                              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                              by ShadowAi
                              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                              03-15-2024, 10:46 AM
                            • meraklinetx
                              Asus Z97-a power cycle, no boot no cpu voltage
                              by meraklinetx
                              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                              05-10-2023, 06:08 AM
