asus k43 first screen stop
  • mrfelc
    • May 2013
    • 8
    • iraq
    asus k43s stop on first screen
    cpu,ram,bios,hdd,io chip replace but not success
    help..
    tanks
  • alibisma
    • Oct 2014
    • 37
    • Saudia
    Re: asus k43 first screen stop
    hi remove the momery card micro SD card
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      check for lan chip short or is it becoming hot when powered on.In many cases coz of bad lan chip it stucks at 1st screen logo.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • FallenOne008
        Asus G712L No Screen Backlight
        by FallenOne008
        Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
        The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
        03-31-2025, 08:27 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • krige
        asus g750js ms1130c (203) turns on nothing on the screen
        by krige
        hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
        03-22-2024, 04:59 AM
      • Technodoc
        ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
        by Technodoc
        Asus laptop G614JZ-N3012W Rog Strix with i7
        Mainboard G634J-PMV-VGT
        6050A3441302-MB-A01
        2023-02-10
        Power button works okay....power light goes on
        Red "bottom" leds go on
        Charging led works
        Fans do not spin, capslock key does nothing, screen stays black
        I would like to program the bios again, to rule out a corrupted bios.
        However I run into a size error
        The bios chip is a Winbond 25R256JVEN
        Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
        02-24-2025, 04:46 AM
