HP G62 No Power- Dead
  • kev4eva
    • Mar 2012
    • 37
    • jamaica
    Good Day, want a few pointers as a seek to troubleshoot
    HP G62 Intel- No power or lights ; no burns or obvious shorts on the board
    Here is what i did so far;
    Verified AC adapter /19.5 volts
    No light from dc jack- disconnect & verify with meter/ 19.5volts in
    Checked the first diode behind power connector on the board and it read ok no shorts.Check a few of the mosfets, read ok, thinking i may have overlooked a bad cap or resistor in the power in circuitry.Any ideas or schematics on this?
    Will appreciate as i try to move forward with it.Will add pics shortly
  • nichella14
    • 29
    • Philippines
    Re: HP G62 No Power- Dead
    i repaired hundreds of g2 with the same problem like yours, mostly BIOS IC Problem
    I just remove the
    1. Bios IC
    2. Plug in AC
    3. Press power on button several times
    4. unplug the AC
    5. Put your bios IC back
    6. and Turn in on again
    • spidey
      climbs
      • Dec 2012
      • 648
      • Cyprus
      did you check the middle pin ?
      • kev4eva
        • Mar 2012
        • 37
        • jamaica
        ok i will try your bios suggestion today and spidey, what did you say about the middle pin?
        • kev4eva
          • Mar 2012
          • 37
          • jamaica
          just tried the bios thing and removed the chip, that didnt work
          • nichella14
            • 29
            • Philippines
            try spidey said, check middle pin voltage, or try other adapter
            try to reset or remount IC,
            if not work try to check Capacitor one by one,
            • nichella14
              • 29
              • Philippines
              i have g62 here now hannstar j mv 6 94v-0 same problem
              • kev4eva
                • Mar 2012
                • 37
                • jamaica
                checking those again and middle pin ok
                • scobie_21
                  • Jul 2011
                  • 144
                  I have had these unit before with faulty bios IC I just replaced with one I reprogrammed
                  • kev4eva
                    • Mar 2012
                    • 37
                    • jamaica
                    if i remove one from another board what are the chances of it solving?
                    • scobie_21
                      • Jul 2011
                      • 144
                      you will still need to flash it with latest g62 bios
                      • kev4eva
                        • Mar 2012
                        • 37
                        • jamaica
                        by using the bios re-programmer?
                        • scobie_21
                          • Jul 2011
                          • 144
                          Yeah you can get cheap ones on ebay that will do the job or a more expensive Willem programmer.
                          • kev4eva
                            • Mar 2012
                            • 37
                            • jamaica
                            http://www.ebay.com/itm/PCB5-0E-Univ...item5656992e47
                            what you think about this one?
                            • kev4eva
                              • Mar 2012
                              • 37
                              • jamaica
                              pics added
                              • scobie_21
                                • Jul 2011
                                • 144
                                That would do but there should be some cheaper types like below. If you repair laptops or desktop motherboards you should have a bios programmer even just to rule out possible bios issue.
                                http://www.ebay.ie/itm/EZP2010-high-...item3378ee279e
                                • kev4eva
                                  • Mar 2012
                                  • 37
                                  • jamaica
                                  delay a bit ordered a smart tweezer online with capacitance tester
                                  • RobRocks
                                    • 13
                                    Hi, its bios failure, i had it many times, the thing is that there are different bios files from the hp website, if you flash the wrong one it will still be dead (also no light at the power socket). Some of the files are not meant to be flashed directly with the programmer they are oversized, the rom file has to be exactly the same size of the bios memory.
                                    • Am0rPHiA
                                      • Nov 2011
                                      • 31
                                      • Greece
                                      i have a couple of these boards with no power at all and no light on the dc socket, no signs of obvious burn or shorts, tried the bios chips but had no success, any ideas?
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • Andreas_de
                                        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                        by Andreas_de
                                        Hello!
                                        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                        04-12-2025, 10:38 AM
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
