HP DV6-3030xt white screen, no lines
  • nucleus
    • May 2012
    • 64
    • Montenegro
    I power it up and it shows white screen without any lines. no any sounds, power light is on, nothing flashes, voltage on every coil is ok, only +vga_core is 0.92v which is pretty low but in schematics is normal between 0.9v and 1v
    nothing on external display, with or without its main display.
    it seams to me like gpu problem, but not sure. anyone had something like this???
  • nucleus
    • May 2012
    • 64
    • Montenegro
    Re: HP DV6-3030xt white screen, no lines
    anyone ??? this is laptop very well known to all of you, someone must have similar failure?
    • masud
      • Jul 2011
      • 317
      • Bangladesh
      graphics(GMCH) problem.
      Reflow graphics chip.
      masud.
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        i fixed hundereds of dv series hp laptops, but didnt see that fault. if you fix it, let me know whats wrong. Btw, did you try to press caps lock to see if the light is on /off. ?
        • nichella14
          • 29
          • Philippines
          Nvidia ATI issue Black out
          • nucleus
            • May 2012
            • 64
            • Montenegro
            I tried it now and it won't stay ON, just blink when I press button, and goes off when I release it.
            also what I noticed now, when keyboard is connected and when put charger in, led light near jack won't light, it just flash once and goes off, and motherboard won't power on. When remove keyboard and connect charger, light is on and motherboard powers on. Also when I first connect charger, then put keyboard it powers on and light on charger jack is on.
            I did reflow it, but no changes. Maybe southbridge is foulty????
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              How about always on voltages? and can you measure current consumption ?
              • nucleus
                • May 2012
                • 64
                • Montenegro
                on choke 3.34v and 5.14v ALW, current was a bit tricky to measure because of third control pin on hp chargers but i got it. power sequence is like this:
                turned off: 0.11a
                turned on: 1.7a, 1.8a, 2.1a, 1.950a and holds it
                this is just motherboard with display no other devices.
                does anyone know what is this thing with keyboard and charging, because I saw that on at least 5 hp laptops
                • nucleus
                  • May 2012
                  • 64
                  • Montenegro
                  does this means something to you??? I didn't watched power sequence for this model until now so I don't know how unusual is this.
                  maybe someone did
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    turned off: 0.11a
                    0.11 is too high for standby. also the others, i think you have battery installed. please remove it and post the new results.
                    • nucleus
                      • May 2012
                      • 64
                      • Montenegro
                      my mistake 0.011A, no battery installed
                      • nucleus
                        • May 2012
                        • 64
                        • Montenegro
                        ok, nobody knows for white screen, but somebody must know this thing with charging and keyboard. what is connection between charging and keyboard ???
                        • spidey
                          climbs
                          • Dec 2012
                          • 644
                          • Cyprus
                          turned off: 0.11a
                          reflow your gpu.
                          • Stanley1843
                            Screen Display Vertical Multicolor Lines
                            by Stanley1843
                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                            06-29-2024, 11:54 AM
                          • harp
                            White screen repairs
                            by harp
                            To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                            Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                            On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                            05-13-2024, 03:43 AM
                          • jeyoung12
                            Samsung QN50Q60t lines on screen
                            by jeyoung12
                            Hi all
                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                            So....i don't know what end of the C ribbon to work with...
                            02-26-2024, 10:38 AM
                          • Ancient1
                            White Screen with Lines. Advice needed
                            by Ancient1
                            Pilot PD43S9HE 43" FHD Smart.
                            Main : HK.T.RT2842P639
                            T-con : Nemu N2TP430FHDLV1D_A1
                            Panel : CC430LV1D
                            I attach photos of :
                            0. The hardware , except the distribution board ( I'll create full view)
                            1. The problem : White screen with horizontal lines ( no Vertical lines ! )
                            2. Disconnection of one of two FLEX from T-con to Panel boards ( in the next post)
                            3. Taping 0.5cm first tracks of the Flex i.e 4 times ( in the next post)
                            Photos include descriptor.
                            Haven't measured anything yet.
                            I'd...
                            10-13-2022, 01:24 PM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
