i have dv6000 hp charging problem it doesn't show charging on screen and cant power on through power adapter but working properly on battery i need help guys how to fix this if anyone have encounter and fix this please help me..
DV6000 not charging,no sign or indication of charging..
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by ThomasraudHello,
i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
QUOTED
-It works on charger (without battery connected-only charger)
-It works on battery (without charger connected-only battery)
-& it also works when plugged in battery & charger, but it's not charging the battery
//Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
and..
QUOTE
The IC cannot maintain the input current level... -
by ScoffLooking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection... -
by ScarfycakeHi all,
I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...5 Photos -
by InstafixxHello Namaste!
I have a macbook a2141 that shows the charging sign when the charger is plugged in but doesnt turn on.
PPBUS_G3H is a good 12.6V.
The amp meter shows its drawing 20V.
The board is clean. I couldnt find any shorted component on the 2v5 SSD lines but the voltage is 0V. Resistance is also 100 Ohms i think it should be 400 ohms.
DFU Revive gets stuck in the middle / I get apple logo and loading bar on the screen. Then i get the lock sign on the Configurator.
Even did a DFU Restore. Same thing happened.... - Loading...
