Macbook A2141 - Charging Sign
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello Namaste!
    I have a macbook a2141 that shows the charging sign when the charger is plugged in but doesnt turn on.
    PPBUS_G3H is a good 12.6V.
    The amp meter shows its drawing 20V.
    The board is clean. I couldnt find any shorted component on the 2v5 SSD lines but the voltage is 0V. Resistance is also 100 Ohms i think it should be 400 ohms.
    DFU Revive gets stuck in the middle / I get apple logo and loading bar on the screen. Then i get the lock sign on the Configurator.
    Even did a DFU Restore. Same thing happened.
    Can anyone help?
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A2141 - Charging Sign
    Originally posted by Instafixx
    Hello Namaste!
    Can anyone help?
    Update - When i press the Power Button / Trackpad, the Fan Starts to spin and the charging logo comes up on the screen. At that time the 2v5 SSD Lines have voltage.
    • Schluchti45
      MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
      by Schluchti45
      i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
      Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
      11-18-2024, 02:05 AM
    • drlarsen
      MacBook Air M1 A2337 battery/charging issue
      by drlarsen
      Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
      I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
      On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
      After some hours, the battery status did not improve. Restore via DFU did not help.
      I connected the power adapter to a Kill-a-Watt...
      07-17-2025, 02:35 PM
    • robka
      MacBook Pro 2018 - A1990 Dead - not charging - only 5V
      by robka
      my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
      I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
      The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
      After that the Macbook was dead. It isn't charging anymore.
      The USB-C Port where the charger was plugged is burned. Also The Cable and the...
      03-02-2024, 02:58 PM
    • sofles
      Macbook Pro 16" A2141 screen artefacts, kernel panic
      by sofles
      Hi there.
      I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
      I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
      Now situation looks like this, If...
      02-05-2025, 05:05 AM
    • Gueric
      Macbook Pro M1 (A2338) 820-02020 not charging.
      by Gueric
      I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
      When plugging the charger : 20v at 0.02 amps.
      pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
      Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
      I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
      07-23-2025, 01:54 PM
