DV6000 not charging,no sign or indication of charging..
  • jachyidz
    • May 2013
    • Philippines
    i have dv6000 hp charging problem it doesn't show charging on screen and cant power on through power adapter but working properly on battery i need help guys how to fix this if anyone have encounter and fix this please help me..
  • Tuomo
    • 163
    • Finland
    Re: DV6000 not charging,no sign or indication of charging..
    There is different DV6000, so do you have schematics?
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      Hello, please check both sides for voltages in these 2 diodes!
      Should have 19 Volts!
      • masud
        • Jul 2011
        • 317
        • Bangladesh
        diode should not have voltage in both side. it must be inductor.
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          No masud.
          Since the diode is connected to 19v, it should have around 19v from one end, and a bit less than 19v from the other end.
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • Thomasraud
            Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
            by Thomasraud
            i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
            QUOTED
            -It works on charger (without battery connected-only charger)
            -It works on battery (without charger connected-only battery)
            -& it also works when plugged in battery & charger, but it's not charging the battery
            //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
            and..
            QUOTE
            The IC cannot maintain the input current level
            06-28-2022, 06:47 PM
          • Scoff
            HP Probook 470 G4 - Power and Charging Problem
            by Scoff
            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
            07-03-2023, 09:28 AM
          • Scarfycake
            ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
            by Scarfycake
            I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
            05-21-2024, 08:16 AM
          • Instafixx
            Macbook A2141 - Charging Sign
            by Instafixx
            Hello Namaste!
            I have a macbook a2141 that shows the charging sign when the charger is plugged in but doesnt turn on.
            PPBUS_G3H is a good 12.6V.
            The amp meter shows its drawing 20V.
            The board is clean. I couldnt find any shorted component on the 2v5 SSD lines but the voltage is 0V. Resistance is also 100 Ohms i think it should be 400 ohms.
            DFU Revive gets stuck in the middle / I get apple logo and loading bar on the screen. Then i get the lock sign on the Configurator.
            Even did a DFU Restore. Same thing happened....
            07-07-2023, 03:16 AM
