toshiba c660d laptop
  • pcpro
    • Apr 2013
    • 9
    Hi all thought i may of found the fix in here but i didnt , i have a c660d that got a broken screen so i changed it the laptop works fine from an external monitor but will not light the screen i can see the toshiba sign but that is it i have had all the fuses checked and there fine also changed the screen cable if anyone has any ides what the problem may be cheers
  • alihomee
    • Dec 2012
    • 1576
    • malaysia
    Re: toshiba c660d laptop
    your screen is a lcd or led
    • pcpro
      • Apr 2013
      • 9
      when i bought it off ebay it says lcd led on the site
      • pcpro
        • Apr 2013
        • 9
        i have the screen working in another laptop so i know its not the screen
        • sparker1
          • Sep 2011
          • 343
          If it is LCD have you tried a different inverter?
          • alihomee
            • Dec 2012
            • 1576
            • malaysia
            if it is lcd then try to check 12v on inverter
            • pcpro
              • Apr 2013
              • 9
              there is no inverter so must be led back lit
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                there are mainly 4 pins for your back light, +, gnd, on/off and brightness. find your mobo. schematic, check lcvd circuit, find the pins. if one of them is missing, find out why.
                • pcpro
                  • Apr 2013
                  • 9
                  sorry to sound thick is that on the mobo or the bk of the screen
                  • spleenharvester
                    • Mar 2010
                    • 903
                    Can confirm the C660D is an LED backlit model. I repaired one of these not so long ago.
                    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                    • ilampos
                      • Dec 2012
                      • 7
                      • GREECE
                      i have the same problem with C660D and i tried everything...other screen...new cable screen...rework vga....clear cmos...nothing.i see this again in a lot toshiba laptop when broken screen change. please someone give an idea...
                      • scobie_21
                        • Jul 2011
                        • 144
                        Read Spidey's comment above....find the schematics locate the pins see if the voltage is missing then find out why..
                        • mpikou
                          • Jun 2013
                          • 58
                          • Greece
                          Greetings,
                          I am facing the same problem here and I am not able to find the exact schematics for this mobo ( PWWBE LA-6846P REV:2.0 ).
                          I tried to solve it via LA-6842P Schematics but it seems to be different.
                          Has anyone located the fuse or the schematics?
                          Thanks in advance.
                          • bluestone
                            • Jun 2011
                            • 343
                            • Ghana
                            Try this
                            • spleenharvester
                              • Mar 2010
                              • 903
                              Originally posted by mpikou
                              Greetings,
                              Thanks in advance.
                              You got any hi-res pics of the board? Some Toshiba boards I've repaired recently have had odd sort of fuses that look like resistors.
                              • mpikou
                                • Jun 2013
                                • 58
                                • Greece
                                Originally posted by bluestone
                                Try this
                                This is exactly the same with the schematic I mentioned before. It did not help me much since it is for 6842p. Thanks a lot for your reply.
                                • mpikou
                                  • Jun 2013
                                  • 58
                                  • Greece
                                  Hope these attachments help.
                                  Thanks in advance.
