hang problem
  • Trigri waley
    • Mar 2013
    • 12
    • Pakistan
    hang problem
    lenovo r400 hang on lenovo logo
    anyone help me in this problem
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: hang problem
    Did you do any bios updates before this? If so that may be the reason.
    Do you get any error beeps?
    Next thing that could be wrong is a corrupt OS.
    Muh-soggy-knee
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      Re: hang problem
      see this thread
      https://www.badcaps.net/forum/showthread.php?t=27589
      • RobRocks
        • 13
        Re: hang problem
        Remove hard drive and optical drive and see if it goes further? Reflash bios, disconnect keyboard or everyting that is not needed, run the naked board with the display? Reseat cpu, reflow southbridge.
        • jtamad44
          • Apr 2013
          • 145
          • israel
          Re: hang problem
          reball sb
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            Re: hang problem
            does anyone can give me the 8mb dump file for the IBM r400 ? i apreciate in advance
            i donwloaded from ibm site , but its a bloody mess , full of files insyde and im not capable for merging it as it should.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: hang problem
              This appears to be a common Lenovo issue. It may be the HDDs that they use.
              Someone I know that has a Lenovo laptop has the same type of deal.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • s_specialist
                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                by s_specialist
                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                07-07-2025, 11:47 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • pkslowk
                Debug Card Error Code and Solution
                by pkslowk
                Sr. Motherboard Debug Error Code Solution
                1 Intel 845 E9 Bios Related Problem
                2 Intel 845 D4 CPU Socket Related problem
                3 Intel 845 37 Bios Related Problem
                4 Intel 845 7C Bios Related Problem
                5 Intel 945GCPE 34 Bios Related Problem
                6 Gigabyte 845 2 Ram Related Problem
                7 IBM Server A6 A7 Ram Mismatch Problem
                8 Asus 845 29 CPU Related Problem
                9 Lenovo I946 97 C-Mos Jumper related
                10 Gigabyte 845 A0 CPU Related Problem
                11 Asrock G31M-VS D7 Bios Related Problem
                12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                01-28-2021, 12:51 PM
              • c.daniel
                Lenovo V310-15IKB weird bios problem...
                by c.daniel
                Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                sn LR09493E
                MB DAOLV6MB6F0 REV. F
                The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                08-22-2025, 05:39 AM
