laptop died - GPU needs reflow?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Hey folks, so, my laptop died. I had it in sleep mode for about an hour then it wouldn't wake up. Or at least the screen wouldn't.
    It is a toshiba satellite L645D-S4036 from 2010
    The power on light becomes white, the hdd light blinks once (HDD spins up and appears to be fine), but no beeps or backlight. This laptop has an led backlight.
    Tried removing hdd, removing and swapping ram, but no beeps. I'm thinking it isn't getting that far in the POST process. Tried removing battery pack, removing CMOS battery, still no luck. No video on the VGA out either.
    Has ATI Radeon HD4520 GPU. CPU is a Phenom II P820 (1.8GHz, triple core). Memory is 2Gb-x2. No burn marks on anything.
    Also, leaving it on in this partly dead state, the heatsink warms up as usual ans the fan turns on when necessary.
    Connectors all look good.
    Ideas? I've got someone who has a shop nearby, he has BGA soldering equipment.
    so, do you think this could be fixed by a simple reflow? (A reball would last longer, wouldn't it?)
    It was a perfectly good computer, before this happened. (Ran windows7 quite speedily)
    Muh-soggy-knee
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: laptop died - GPU needs reflow?
    take a mild reflow to confirm that its the gpu giving a no display fault. - if positive, reball
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      or try the basics first. remove power adapter and battery. press and hold power button for at least 15 seconds. try it with battery
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Probably needs a reflow. just had an HP with a Radeon HD4250 with a bad chip.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          A bad chip or bad solder balls? Lol I think I meant HD4250 also, I keep switching them xD
          That was the first thing I did actually xD
          Muh-soggy-knee
          • senndogg
            • Dec 2011
            • 383
            • Albania
            in this case it will be bad solder! Usually these ATIs dont fail, even if they fail they are so cheap...
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Good to hear, I agree too, mainly because the failure was after the computer cooled down - when it cooled down the solder just gave-way. But I don't want to be too optimistic, incase something else is wrong
              Muh-soggy-knee
              • tmiha71
                • Apr 2010
                • 130
                I do wonder, what capacitors are used in laptop VRM's... It looks like they never did failed...
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Contrary to the problems with the capacitor made by 'nec-tokin' in toshiba laptops, my laptop doesn't have one. It has a handful of smaller rectangular, black capacitors.
                  Muh-soggy-knee
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Time for a Lenovo or Dell, then?
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Not yet. Going to have reflowed first.
                      Muh-soggy-knee
                      • senndogg
                        • Dec 2011
                        • 383
                        • Albania
                        i am pretty sure it will gain extra 3-12 months life after reflowing.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Reballing would last longer, right?
                          Muh-soggy-knee
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            ^ If done properly with leaded solder, it should.
                            • senndogg
                              • Dec 2011
                              • 383
                              • Albania
                              totally agree with that!
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Yeah I've been thinking the same thing. At least a web search suggests that it will be longer lasting. I kinda liked this computer, so I wish it will last a long time xD
                                Muh-soggy-knee
                                • tmiha71
                                  • Apr 2010
                                  • 130
                                  @ben7
                                  Something like this, see picture, they're probably the same (or very similar), some kind of poly, but (pictured) ONLY 1000 h at 85 degC, those on the picture are NEC-TOKIN, so called NEOCap....
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    @ben7
                                    HA yes they look just like that. 1000 hours?! That isn't nice. I'm sure they ran quite close to 85C, if not more!
                                    Now I do wonder if one has gone short, or the like!
                                    Muh-soggy-knee
                                    • tony359
                                      Reflow equipment
                                      by tony359
                                      Hello all,
                                      I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                                      I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                                      Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                                      12-25-2021, 01:29 PM
                                    • Mr_Nada
                                      Concerns before attempting a Reflow of Laptop's GPU
                                      by Mr_Nada
                                      I saw some posts at one point talking about doing a reflow but I couldn't find them again so I thought that I would post this here.
                                      I plan on reflowing the GPU of this old HP DV2500 laptop but I want to go over what I have and the steps I have to take to guarantee it will come out fine.
                                      I have a Yihua 8786D 2in1 Rework station, flux (just some paste that I got from an old Radioshack kit), a couple rolls of Kapton tape and a $15 Thermometer +probe (a TM902C from EMR shielding Solutions if its important).
                                      • The paper that came with the thermometer states that the probe
                                      10-10-2024, 02:53 AM
                                    • howardc64
                                      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                      by howardc64
                                      TV was fixed just after removing Samsung's rear snap cover.
                                      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                      Maybe PSU->backlight connector didn't have a good contact?...
                                      07-23-2025, 12:34 AM
                                    • mustardcheese
                                      Question about removing the BIOS lock
                                      by mustardcheese
                                      Hi all, I have a Dell Latitude 7300 with a locked BIOS and I was curious about the process of removing the lock by editing the hex values of the bin and how to do it. Is editing the hex values of the dumped bios any different than flashing a new one that's already been unlocked? (I currently don't have the correct bin because I realize I accidentally dumped the wrong thing). I am very new to this any help or advice or references would be greatly appreciated. Thanks
                                      06-17-2025, 10:25 PM
                                    • groomit
                                      Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
                                      by groomit
                                      I just replaced the battery on a Google Pixel 5.
                                      After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
                                      Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
                                      The rubber seal is on again (as mentioned in various suggestions in other forums).
                                      This smells like a cold or broken solder joint. So I'd like to reflow...
                                      06-11-2025, 02:21 AM
