acer 4736z auto off power
  • sangel30
    • Jul 2012
    • 24
    • philipines
    i have acer 4736 wen i power it its outo off power ..sometimes its have dispaly and off again pls help
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: acer 4736z auto off power
    You may have a short on secondary power circuit or a circuit connected to secondary, or a thermal issue.
    • are-red
      • Feb 2013
      • 24
      • malaysia
      Proadlizer , replace that..
      • nambtv
        • Mar 2013
        • 7
        • vietnam
        replacement capacitor nectokin cpu
        • sangel30
          • Jul 2012
          • 24
          • philipines
          what is proadlizer and nectokin cpu
          • spidey
            climbs
            • Dec 2012
            • 644
            • Cyprus
            check for a nec/tocin cap. behind cpu socket.
            • sangel30
              • Jul 2012
              • 24
              • philipines
              i replace nec tokin but same problems wen i open power comes to bios its not dead but wen i install os in its its off again
              • sangel30
                • Jul 2012
                • 24
                • philipines
                thanks to all i solve the problems bad net tokin
                • kenttech16
                  • Oct 2011
                  • 27
                  • Philippines
                  What did you do then to solve the problem? replaced with nec tokin or SMD caps?
                  • welhim
                    • Feb 2013
                    • 40
                    • philippines
                    do you some pics when you do NEC TOKEN??...probably you need to make it 5 capacitors 330.....i did it one time it works on a toshiba laptops.....hope it helps you,,,
