what is the way to remove the hdd password for all laptops???????????
HDD passsword remove
Tags: None
Re: HDD passsword remove
Contact the manufacturer enclosing all the details Make Model and service tag
enclose copy of proof of purchase. And explain why you need it.Please upload pictures using attachment function when ask for help on the repair
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by Maxpower3every time I open the tool, I have the screen that appears
and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
It annoys me lol.
2 solutions to remove it.
Either you remove pic.bmp and it no longer appears so no more links when clicking.
hope this helps users...01-15-2025, 03:24 PM -
by ANAOOSHello everyone
I have locked bios dell pc OptiPlex 3000 Tower
I need to remove bios password
or if anybody can help me how to remove it by my self
Thank you !!...-
by gustoI am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
Fortunately, I'm testing it on old network switches to see how it works.
What am I doing wrong?
I've seen a lot of videos on youtube and everyone got the solder melted and the... -
by acataI am working on Asus X441UV with Nvidia 930mx 4gb.
The whole power rail is fine except the GPU heats up at the first boot.
is it possible to remove the entire GPU component and flash a similar BIOS?
FYI:
I don't have a BGA workstation so the option is just to remove all GPU components with Hot Blower QUICK 850 analog and solder.... - Loading...
