Alternative Component: IC
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Hi everyone
    I have here a Samsung GT-P7500. It has no power. Im looking for an IC: "8903CE TI203 ITHK +". It's not on the web anywhere. Can anyone share the alternative to use instead?
    Could not find a datasheet for it but found this on Mouser: http://uk.mouser.com/ProductDetail/M...IigyR6icslA%3d
    Thanks!
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Alternative Component: IC
    Originally posted by speedypro
    Hi everyone
    Thanks!
    Wow, a galaxy tab that is broken?
    Have you checked all the voltage rails for shorts, or just no voltage/wrong voltage?
    Otherwise, the chip could be the problem. It is a battery charger chip.
    Also check the voltage from the battery terminals, to see if the battery is OK. If it is lower than 3v then I sugguest you replace it. When discharged too much, the LiPO batteries will bloat and possible blow up when charged again...
    Muh-soggy-knee
    • speedypro
      • Feb 2013
      • 561
      • United Kingdom
      Hi
      Sorry but the part is 8903CE TI150 ITHK +. But yea the battery is not the issue as without the battery is should still out put charging voltage. I do have a service manual and it leads to the IC being damaged. But I need the part. The mouser link above is the only alternative I've seen.
      And yes a Galaxy tab that is broken
      No voltage to battery so that would conclude faulty IC. 30-50 pin cable is ok.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Hi
        NO voltage at the battery? That doesn't sound good!
        Muh-soggy-knee
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • ruletero
          Acer a515-43 low battery charge voltage
          by ruletero
          Hi
          Acer A515-43
          LA-H801P
          Fail: Does not charge battery, has low voltaje on connector.
          Laptop didn't want to turn on, only charge led blinked.
          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
          10-24-2022, 02:31 PM
        • questore
          XPS 13 9370 CMOS battery voltage always low
          by questore
          Hi Everyone,
          I have brought you a mistery item
          This laptop have come with some strange faults.
          1. CMOS battery was flat 0v
          Symptoms:
          - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
          Amp drawing was stuck at 0.005 milliamps.
          - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
          After inverstigation RTCD1 diode had a low value...
          09-30-2025, 05:47 AM
        • guruji
          samsung galaxy book 3 np940xfg battery charge
          by guruji
          hello
          I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
          my...
          08-14-2025, 08:12 AM
        • Sean Devine
          Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
          by Sean Devine
          UPS turned off one night and it seemed that the 3 year old batteries gave out.
          Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
          ...then I found various Cyberpower threads here with some guidance on what to check.
          C1 (22uF) tested at 2, so I replaced that.
          Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
          03-03-2025, 08:23 PM
