HP Dv6800 Southbridge reflow /Optical Drive detection
  • heavymachines
    • Mar 2011
    • 1028
    Re: HP Dv6800 Optical Drive detection
    Originally posted by thesloc
    Yep, although any good BGA station should have one already (a thermocouple thermometer).
    Look up how some professionals do it on YouTube, particularly "BGAReflow" which I think is one of the best reflowers out there.
    i use k type thermalcouple and and a reflow station works great...never killed anything on reflow....however reball is another story that has me needing lots of practice lots and lots of practice extremely challenging...
    • heavymachines
      • Mar 2011
      • 1028
      Re: HP Dv6800 Southbridge reflow /Optical Drive detection
      Originally posted by nish_pinto
      Looking at the diagram, can anyone tell me what is Soak Time?
      means letting the heat soak in for a period of time...
      • heavymachines
        • Mar 2011
        • 1028
        Whatever... Worst comes to worst, I can part it out. But I'd rather fix it...
        should have no issues, i reflowed more hp dv series then i can count and funny thing is you will be surprised how there are different revisions of same darn model and how the entire line of dv from 2000 to 9000 all have this issue...and some of them have extension cards some don't ...good luck....
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by heavymachines
          copper shims help a lot with temps works better, a lot of laptop manufactures use tin foil with thermal compound on both sides, all the copper shim does is make tighter contact with the die and has better heat transfer then the aluminum foil that i see a lot in laptops... it drops the temps down very well and speedfan shows nice lower temps...but hey everybody has opinions...
          I respect your opinion but from a mechanical point of view, the pad is more than just a non-metal shim... it actually uses the "squish" of the pad to ensure even contact.
          Generally, the CPU is the only device w/o a pad; it gets anchor bolts from all sides of the chip. However, in order to contact the other chips while still contacting the gpu and to allow height tolerances on both the chips and heatsink, a method of thermal contact that allows slight height and/or contact angle variances is required.
          The reason contact angle also comes in is that since the non-CPU chips are effectively clamped from only one side, the angle of contact will actually be ever so slightly less than 0 degrees.
          Not to say you couldn't get away with a shim... but understanding the mechanical engineering involved with heatsink design, I'd rather be safe than sorry.
          The BGA station doesn't have a thermocouple probe or thermometer... just an air temperature indicator (and a soldering/desoldering gun/iron thingy). It's made by black jack.
          sigpic
          (Insert witty quote here)
          • thesloc
            Banned
            • Dec 2011
            • 587
            looking at the diagram, can anyone tell me what is soak time?
            150 c
            • thesloc
              Banned
              • Dec 2011
              • 587
              #26
              You need to find one, even a cheap IR thermometer will do. Just anything to let you know what the real surface temperature on the chip is.
              • trebo
                • 514
                • Wales, UK
                #27
                Generally, the CPU is the only device w/o a pad; it gets anchor bolts from all sides of the chip. However, in order to contact the other chips while still contacting the gpu and to allow height tolerances on both the chips and heatsink, a method of thermal contact that allows slight height and/or contact angle variances.
                I am of the same opinion as you, they cant lie flat,
                thats why thermal pads are used in the first place by the manufactures, and continue to be use bye them.
                Still it would be better if GPU etc were all screwed down, (we can dream on)
                • thesloc
                  Banned
                  • Dec 2011
                  • 587
                  #28
                  Why couldn't they let the GPU be removable like the CPU?
                  • heavymachines
                    • Mar 2011
                    • 1028
                    I use phidget system with a netbook and a k type thermocouple works good and got it used on ebay complete setup for 30 bucks here a link to what the pcb looks like http://www.phidgets.com/products.php?product_id=1051_2 hope that helps ya if you don't have one...
                    • heavymachines
                      • Mar 2011
                      • 1028
                      We all could wish for that idea!!! Then laptops would rock when it's time for upgrade!!! however some models, albeit super expensive laptops like alienware, falcon northwest have removable grapics cards , some older dell's had removable graphics but proprietary to dell not standardized like mxm tech.
                      I would say the most likely reason they don't do that is cost,,,they want to sell tons of laptops and adding sockets or slots adds lots of cost and they have profits in mind.
                      • opamp
                        • Dec 2012
                        • 160
                        • united states
                        #31
                        Take a look at this cheap multimeter it's a cen-tech p37772. It comes with temperature setting and should work for a reflow . The're available in any harbor freight stores for around 20 bucks or try ebay you might get lucky and find it cheaper.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          No thanks.
                          I'm getting a real multimeter (not some HF POS) soon with a temp probe. Like a UEI 393 or Extech 530.
                          sigpic
                          • opamp
                            • Dec 2012
                            • 160
                            • united states
                            #33
                            I know this is a disposable meter, I meant to get it just for the reflow purpose (cheap thermocouple). It seems to me it would be overkill to get a $200 meter to fix a $20 board (no offense) but then again your expensive meter would pay for it self if you keep doing reflows.
                            • thesloc
                              Banned
                              • Dec 2011
                              • 587
                              #34
                              Haha, yeah, even I've used the thermocouple on my even to do successful reflows.
                              It's all about technique.
                              • nish_pinto
                                The Adventurist
                                • Oct 2011
                                • 83
                                • India
                                #35
                                I just got 2 copper shims from ebay. Shall compare temp results with and without the copper shims. Thanks for the information you provided.
                                http://nishantpinto.blogspot.in/
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Did the reflow today... and after a quick laptop rebuild, it so far is running well. Posting from it now via Live USB (my live cd still in the drive booted fine too).
                                  Thanks to everybody who helped in this thread.
                                  sigpic
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    #37
                                    What method did you use?
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      BGA station, paste flux, and a mutimeter with temp probe?
                                      edit- I also used the temp profile posted in this thread.
                                      sigpic
                                      • thesloc
                                        Banned
                                        • Dec 2011
                                        • 587
                                        #39
                                        Good job !
                                        What type of BGA Station? What kind of flux ?
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          Good job !
                                          Some Blackjack BGA/Soldering combo station the College has in the lab
                                          Flux was a Syringe of MG chemicals Rosin Paste flux I had leftover from a previous oven reflow.
                                          sigpic
                                          • 08caine15
                                            X455LJ REV 2.1 Optical Drive and HDD Drive cannot detect
                                            by 08caine15
                                            Hi sirs, im having a bit of a problem it's my first time encountering this kind of issues . anyone knows how and what to check in this kind of issues, at first the bios doesn't even recognize the hdd and it automatically enter bios like 1 second but when I put the ODD it feels like it 's trying to read it but still it's still not showing in bios .
                                            what's odd is when I only put the HDD , in SATA configuration it shows SATA 1, SATA 2, SATA 3, SATA 4 and so on . when there's only two SATA SOCKET, then i put the ODD then it only shows SATA 1 which it says NOT CONNECTED. tried to reprogram...
                                            08-17-2025, 11:21 PM
                                          • federalhouse
                                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                            by federalhouse
                                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                            **Background:**
                                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                            **What I've Tried So Far:**
                                            1. I accessed
                                            08-01-2024, 07:03 PM
                                          • perfm2
                                            HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                            by perfm2
                                            So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                            Steps taken in my usual process.
                                            Reset security settings in the BIOS
                                            Ensure existing HD comes up into the OS
                                            Shut down the laptop and disconnected the main battery
                                            Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                            Replace battery connector and close up the laptop
                                            Insert my USB drive with my Windows 10 image I've...
                                            03-21-2023, 08:45 PM
                                            HP Elite Slice G2 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + LaCie Porsche Design USB 3.0 1TB Mobile Drive can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and Elite Slice G2 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-12-2024, 02:20 PM
                                            Pegatron M2N78-LA (rev. 3.02) freezes on POST with SATA drives attached
                                            by momaka
                                            Like the title says, I have a Pegatron M2N78-LA (HP P/N: 513430-002) motherboard out of an HP Pavilion PC. The motherboard hard-locks during POST when it gets to the part of trying to detect the SATA devices *only* if there is a SATA device (be it HDD or optical drive) connected to any of the SATA ports. I cannot enter BIOS or do anything when this occurs. Pressing Ctrl+Alt+Del cannot restart the system either. In fact, the keyboard locks up too (Num Lock status LED cannot be toggled anymore.). However, if I disconnect everything from the motherboard's SATA ports, the motherboard can POST successfully...
                                            11-28-2020, 11:08 PM
