Emachines D725 Keyboard and touchpad not working
  • valiant007
    Comp Technician
    • Dec 2012
    • 44
    • philippines
    Hi guys,
    Just wanted to ask you guys if you encountered this problem. The keyboard and touchpad were working fine until a week ago when it finally stopped working. i tried all the shortcut keys on the keyboard maybe it was just disabled but everything was ok there. Next thing i did was uninstall and reinstall the drivers, still the same. And the last thing i did was try with a new keyboard but with the same result. All the keys on the keyboard dont work same with the touchpad, no response. If you guys have any suggestions on how to fix this problem i would greatly appreciate it.
    P.S. it works with usb keyboard and mouse but not with the internal keyboard and touchpad.
    Thank you in advance.
    _________________________________________________________________
    Free Computer Service!!!!!!!!!
    If We can´t Fix the problem.
  • Taxman
    • Nov 2012
    • 45
    Re: Emachines D725 Keyboard and touchpad not working
    Don't know if this is relevant to your particular model, but on other emachines you can unwittingly lock the touchpad if you press the button next to the power button...
    • heavymachines
      • Mar 2011
      • 1028
      well sounds like hardware issue but to fully rule out software or drivers boot with hirens boot cd and log into mini xp or ubuntu portable and see if you can regain keyboard functions if you can then its software related however if still no go then its certainly hardware without a doubt....
      • valiant007
        Comp Technician
        • Dec 2012
        • 44
        • philippines
        thanks for the advice. i tried that button but still the same.
        • Taxman
          • Nov 2012
          • 45
          From memory of working on a friend's mchine a while back, I think pressing Fn and F7 also locks / unlocks the touchpad.
          You said you uninstalled the drivers. Did you actually uninstall the devices? Normally Windows (or whatever system you use) would automatically reinstall the devices on reboot.
          Could be a virus too of course. Encountered that recently on another machine that was infected by the West Yorkshire Police virus. Unlikely though, as you'd have seen the threatening messages first asking you to pay the 'fine'.
          Does everything work properly in BIOS?
          • valiant007
            Comp Technician
            • Dec 2012
            • 44
            • philippines
            thanks for your advice, i tried booting it up on hirens but with the same result. seems to be a hardware problem. do you have any suggestions where i can check for the hardware prob?
            • valiant007
              Comp Technician
              • Dec 2012
              • 44
              • philippines
              i tried that already. it does not work also on the bios. and i tried also booting up on hirens on my flashdrive. touchpad and keyboard does not work there either.
              • Taxman
                • Nov 2012
                • 45
                Odd. If it was the keyboard alone then I'd maybe suspect a loose ribbon, but not when it's both devices. Have you tried a cold reset? Unlikely to resolve your problems but sometimes does fix the most unusual faults - switch off, remove battery, power plug and all attached devices, then hold power button for 30-40 seconds then plug everything back in and power up again. As I said, unlikely to be a fix, but sometimes...
                • Taxman
                  • Nov 2012
                  • 45
                  PS Keep the battery out when first restarting after a cold reset.
                  • valiant007
                    Comp Technician
                    • Dec 2012
                    • 44
                    • philippines
                    thanks for the advice, i tried the solution you suggested. both still dont work. i even tried taking out the cmos battery just out of curiosity but i still got the same result, no response from keyboard and touchpad.
                    • Taxman
                      • Nov 2012
                      • 45
                      Apologies if I'm stating the obvious but just in case you overlooked it -you did restart WITHOUT the battery yes?
                      • valiant007
                        Comp Technician
                        • Dec 2012
                        • 44
                        • philippines
                        yes i did. i followed your instructions by the book.
                        • Taxman
                          • Nov 2012
                          • 45
                          Stumped. Particularly since they're not working in BIOS mode. Do you get a keyboard error message when starting? If the system doesn't detect a keyboard then I'd expect to see that message (and hear a beep) early in the boot process. If you're not getting that message though, it would suggest that the system believes there is a keyboard there... albeit that it clearly isn't working.
                          If I can think of anything I'll get back to you.
                          • Taxman
                            • Nov 2012
                            • 45
                            Another possible cure that worked for others having same problem on a different Acer model - disable the battery controller in the device manager. Can't see how this would resolve matters though when you've already tried using it with the battery removed, but nothing to lose by trying.
                            • Taxman
                              • Nov 2012
                              • 45
                              Another random thought - any Logitech drivers on your system? Been racking my brains and just remembered a similar problem on another system a few years ago. It had Logitech drivers (can't remember if they were for camera or mouse or whatever) and everything had been working fine until the keyboard/mouse problem unexpectedly occured. No idea why the conflict arose given that everything had been fine previously, but removing the Logitech drivers fixed it.
                              • Taxman
                                • Nov 2012
                                • 45
                                if all else fails, there's always the system restore option of course... if that is indeed an option...
                                • Taxman
                                  • Nov 2012
                                  • 45
                                  Ordinarily I'd also suggest checking to ensure that the keyboard is properly connected but judging by your initial post I'm taking it for granted that it is indeed connected properly.
                                  • Taxman
                                    • Nov 2012
                                    • 45
                                    Fn & F6?
                                    • valiant007
                                      Comp Technician
                                      • Dec 2012
                                      • 44
                                      • philippines
                                      thanks for your suggestions but those suggestions are software related. if the keyboard would have worked on the bios then those suggestions could work but keyboard and touchpad does not work on bios and on windows live when i boot to my flash drive so it cant be a software problem. even reformat cant work, but just for the fun of ill try all your suggestions. thanks again.
                                      • Taxman
                                        • Nov 2012
                                        • 45
                                        Apologies - just noticed you're a computer technician, hope I didn't insult or offend by stating options that would have been obvious to you. Good luck :-)
                                        • User555111
                                          A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                                          by User555111
                                          Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                                          02-05-2024, 08:16 AM
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • fichamba
                                          MSI GL75 Leopard keyboard (almost) not working - HELP
                                          by fichamba
                                          Hello everybody:
                                          Let me put all the laptop's info before describing the problem:
                                          BRAND: MSI
                                          MODEL No.: MS-17E7
                                          SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
                                          MoBo: MS-17E71 VER. 1.0
                                          This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
                                          This time I also observed that the right...
                                          10-09-2024, 04:53 PM
                                        • Vliegenier04
                                          Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                                          by Vliegenier04
                                          Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                                          I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                                          Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                                          06-16-2025, 12:03 PM
                                        • hopkok
                                          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                          by hopkok
                                          Hi masters, I need your help.
                                          I am working on Lenovo Legion 16ITHg6
                                          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                          Power LED is not working as well, power button working well.
                                          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                          Motherboard...
                                          05-04-2025, 09:35 AM
