HP mini 110 HP mini 210
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    always on (3v, 5v) present , but not switching. did someone already get this kind of isssue ????????????
  • heavymachines
    • Mar 2011
    • 1028
    Re: HP mini 110 HP mini 210
    need more details.....worked on a few dell mini's whats the whole story on this beast?
    • lord
      • May 2011
      • 319
      • Croatia
      I worked on HP Mini 2133, and 90% cases is the soldered CPU needing a reball
      • primoz1
        • Oct 2010
        • 270
        • Italy-Slovenia
        Hi is any chance to buy new CPU for HP mini 210 ?
        I got this mini to repair, but before is stand a fey month god know where and pickup moisture, so on 160 deg C° CPU start popcorning.
        Thankyou for support.
        • are-red
          • Feb 2013
          • 24
          • malaysia
          Reflow processor or reball
          • primoz1
            • Oct 2010
            • 270
            • Italy-Slovenia
            I try reflow as always, to see if will help, if Im 100% what is problem then make reball.
            In this case processor got popcorn effect like I say on 160 deg celsius, which is far below from 200-220 so only thing who may cause popcorn is moisture.
            • boodeey
              • Nov 2011
              • 7
              yes .. i try to reflow this model several times
              and always turn popcorn
              www.servicenotebookjakarta.com
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                You guys mean that there is burning and sparking/crackling sounds? Or you mean there is steam and boiling water sounds?
                I doubt it would be from moisture, like, there must be a LOT of moisture in there to make steam and boiling sounds.
                Muh-soggy-knee
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  first flash bios. also check ACIN and LID signal.
                  • Techie666
                    • Feb 2013
                    • 23
                    • Mexico
                    what it means is that the cpu/gpu/bga of any kind will form little bubbles on top or bottom of the chip. it will usually make popping sounds in the process.
                    this can be caused by moisture, this doesnt mean its visibly wet, it could be a slight, non visible condensation from cleaning with alcohol or other solvents. they may sometimes sip through the surface of the chip and when heated, will form gases, these gases try to exit the surface and pop the chip in the process.
                    In my opinion the biggest reason for pop corn effect is heat. either too much heat or heating the component too quickly.
                    To reflow this kind of chip, I would suggest preheating starting with low heat around 50° C from a bottom heater for a couple of minutes, then increase heat slowly to reach 100° C within 5 minutes (this can go higher depending on size of the chip, i've done up to 150° with nvidia gpus) then start applying upper heat in slow bursts or a slow ramp if your using a bga reballing machine, up to usually 180° for chips that are as thin as most cpus we find in mini laps, up to 220°C for bigger chips. try to keep good track of your temps and never exceed 200° when reflowing small cpus.
                    To answer the thread, I've also found the cpu solder to be the problem in this particular laptop several times as well as in 220,2133, 2140 etc. reflow and or reball has been the solution.
                    Cheers
                    • YanElec
                      • Sep 2012
                      • 8
                      • Indonesia
                      Yeah just same with me
                      intel atom always get popcorn and hard to repair because replace the chip was very expensive price and delivery (no one sold in my country).
                      very frustrating
                      yan elec
                      servicelaptoppalu dot com
                      • primoz1
                        • Oct 2010
                        • 270
                        • Italy-Slovenia
                        Must prebaked chip to avoid popcorning, moisture is in that chip, and than start make bubbles becasue of that. Find Intel data sheet for that atom and find part where talk about baking, but usual must bake on 80-120 deg C for 24h sometime even week, depend on manufacturer specifications for that part.
                        • YanElec
                          • Sep 2012
                          • 8
                          • Indonesia
                          preheat for 24h long ? woow its long day. but need to try
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1490
                            • portugal
                            got the same issue , mine have 3.3 and 5 also switch on off drop to 0 once its pressed , reflashed bios , replaced NM10 , still the same ,
                            anyone found what was the problems ?
                            • chrizzclo
                              • Aug 2014
                              • 17
                              • Indonesia
                              Hello, anyone here that know the symptoms if the atom processor fail?
                              I have Asus X101H power on but no video on internal or external screen. All voltage is present and normal. The atom processor is n455, only get very little warm (i check without heatsink and fan, never get hot even it powered up to 10 minutes) when powered on.
                              It is processor (n455) or chipset (cg82nm10) faulty?
                                by sam_sam_sam
                                03-31-2024, 02:12 PM
                                HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                09-12-2024, 02:20 PM
                                by sam_sam_sam
                                07-01-2024, 06:34 AM
                                HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) EliteDesk 705 PRO A6-8500B Specification for Upgrade or Repair
                                This specification for the HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) boardview and EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                09-12-2024, 03:36 PM
                                HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) EliteDesk 705 PRO A8-8600B Specification for Upgrade or Repair
