always on (3v, 5v) present , but not switching. did someone already get this kind of isssue ????????????
					HP mini 110 HP mini 210
 Re: HP mini 110 HP mini 210
 I try reflow as always, to see if will help, if Im 100% what is problem then make reball.
 In this case processor got popcorn effect like I say on 160 deg celsius, which is far below from 200-220 so only thing who may cause popcorn is moisture.Comment
 yes .. i try to reflow this model several times
 and always turn popcorn
 www.servicenotebookjakarta.comComment
 You guys mean that there is burning and sparking/crackling sounds? Or you mean there is steam and boiling water sounds?yes .. i try to reflow this model several times
 I doubt it would be from moisture, like, there must be a LOT of moisture in there to make steam and boiling sounds.Muh-soggy-kneeComment
 what it means is that the cpu/gpu/bga of any kind will form little bubbles on top or bottom of the chip. it will usually make popping sounds in the process.
 this can be caused by moisture, this doesnt mean its visibly wet, it could be a slight, non visible condensation from cleaning with alcohol or other solvents. they may sometimes sip through the surface of the chip and when heated, will form gases, these gases try to exit the surface and pop the chip in the process.
 In my opinion the biggest reason for pop corn effect is heat. either too much heat or heating the component too quickly.
 To reflow this kind of chip, I would suggest preheating starting with low heat around 50° C from a bottom heater for a couple of minutes, then increase heat slowly to reach 100° C within 5 minutes (this can go higher depending on size of the chip, i've done up to 150° with nvidia gpus) then start applying upper heat in slow bursts or a slow ramp if your using a bga reballing machine, up to usually 180° for chips that are as thin as most cpus we find in mini laps, up to 220°C for bigger chips. try to keep good track of your temps and never exceed 200° when reflowing small cpus.
 To answer the thread, I've also found the cpu solder to be the problem in this particular laptop several times as well as in 220,2133, 2140 etc. reflow and or reball has been the solution.
 CheersComment
 Must prebaked chip to avoid popcorning, moisture is in that chip, and than start make bubbles becasue of that. Find Intel data sheet for that atom and find part where talk about baking, but usual must bake on 80-120 deg C for 24h sometime even week, depend on manufacturer specifications for that part.Last edited by primoz1; 09-26-2013, 07:30 AM.Comment
 Hello, anyone here that know the symptoms if the atom processor fail?
 I have Asus X101H power on but no video on internal or external screen. All voltage is present and normal. The atom processor is n455, only get very little warm (i check without heatsink and fan, never get hot even it powered up to 10 minutes) when powered on.
 It is processor (n455) or chipset (cg82nm10) faulty?Last edited by chrizzclo; 08-26-2015, 08:15 AM.Comment
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
			This specification for the HP Stolnà poÄÃtaÄ 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolnà poÄÃtaÄ 260 G3 Mini boardview and Stolnà poÄÃtaÄ 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-12-2024, 02:20 PM
			by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
			This specification for the HP EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) boardview and EliteDesk EliteDesk 705 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-12-2024, 03:36 PM
- Loading...
