hp 6830s dead
  • jpatrice22
    • Oct 2011
    • 39
    hp 6830s dead
    hi can someone gives the schematic of a hp6830s please.thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp 6830s dead
    here you go
    Im Back... sort of...
    • lord
      • May 2011
      • 319
      • Croatia
      Re: hp 6830s dead
      Did you manage to repair it and what was the issue?
      • tomodachi
        • Apr 2012
        • 607
        • Turkey
        Re: hp 6830s dead
        yeah, can you share the results please ?
        • jpatrice22
          • Oct 2011
          • 39
          Re: hp 6830s dead
          thanks man, for sharing.i will work on it this weekend, keep you in touch.......
          • jpatrice22
            • Oct 2011
            • 39
            Re: hp 6830s dead
            hi, it's not the good schematic.the board's name is
            foxconn
            MLI-H94V-0
            E253117
            please help.....
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Re: hp 6830s dead
              foxconn
              MLI-H94V-0
              E253117
              please help.....
              Could you get us some pictures please?
              I see that this is a laptop, not a desktop.
              A few questions:
              1. Have you made sure the CPU is good?
              2. Have you ruled out the PSU?
              3. Have you checked for any bad/shorted memory?
              4. Have you checked for shorts on the power rails of the motherboard?
              5. Is the video GPU dead?
              Muh-soggy-knee
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • disorder
                ps5 edm-033 dead after hdmi/usb ports destroyed
                by disorder
                hello guys,
                i need help to repair a edm-033 ps2
                history : as always hdmi port and usb ports destroyed after unplugged
                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                so i changed it
                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                i don't see any projection of liquid metal on pcb.
                01-14-2025, 12:48 PM
              • zunasthegreat
                Chieftec GPS-450-AA with dead 20N60C3
                by zunasthegreat
                Hello everyone hope all doing well!
                I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                09-01-2024, 07:12 PM
              • Beton
                Finding a dead short component
                by Beton
                Hi guys!
                I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                I have a bench PSU and if I try to inject voltage the voltage...
                12-10-2021, 01:05 PM
              • FiguringITout
                MSI Raider GE75 - Not posting, probable dead CPU
                by FiguringITout
                Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                07-25-2024, 07:27 AM
